hey guys havent used the forum in ages but i need some urgent and honest opinions
finally sold the non turbo R33 which ive had for 4years now and its time to upgrade
and im still trying to decide between an R34 and an an S15 i know this is a stupid question to ask in a Skylines forum but i basically wanna spend around the mid 20's on it and im after something with low k's and some minor mods
so first question is R34 or S15? i originally had my heart set on an R34 but seems i can find a cheaper S15 with less K's for around the same price
but im guessing an R34 would be a better drive and more power?
i imported the last car and am still deciding on whether to import again
im not the most patient of people so waiting 8-12 weeks will kill me plus ill be without a car and have to organise a rental
but i believe ill save around 5grand after looking into it
so second question is import or not? ive also found that there a fair few cheaper ones over east has anyone bought a car over east?
any help would be muchly appreciated thanks!
https://www.sau.com.au/forums/topic/168639-time-for-a-new-car/
hey i had this problem when i was looking.
but my opionion i think the r34 would have lower k then a s15 would because its newer but not sure depends but u can get some from dealers that are freshly imported but they already here so u dont have to import ur self. it also depends on waht u want the car for the r34 will be heavier then the s15 but in the end its up to u. but u should be able to pick up a nice car with mods botht the r34 and the s15. so i say just keep looking and ul find a winner. hope this helps
S15 FTW!! awesome handling and SR20 midrange torgue!
Personal preference mate but they both have strengths and weaknesses ie:
S15
+ awesome midrange torque
+ very good chassis balance, handle great
+ look like sex on wheels
+ parts can be cheaper
+ flat thirteens should be doable on stock turbo
- six speeds break :)
R34
+ bigger car
- heavier front end dulls handling
+ sounds awesome
+ tougher driveline
+ wishbone front end
"but im guessing an R34 would be a better drive and more power?"
not much real HP difference when modded(stock turbos)
plus the vehicle weight. . .
that help?
"weird i thought the only difference with spec s and r was sun roof and 6 disk stacker. and the spec r was a little slower due to extra weight?
unless the jap versions had more power and the aussie delivered as the same"
AUS SPEC S = 200 hp S14 config motor
AUS SPEC R = as above but more trim options
JDM SPEC S = N/A Motor
JDM SPEC R = 250 HP BB turbo, bigger injectors, tune etc.
This is the general consensus, but there is still arguement about it. . .
so if you get an imported JDM R spec you get a better motor and the possibility of plenty of JDM trim options
the debate continues!!
there are bugger all r34s in dealers at the moment it seems , budget 30k for a nice manual coupe
aus spec s15 does not quite have a s14 spec motor , ecu and turbo is different . some aus s15s have bb turbo also
basically though 147 aus vs 185kw jdm
the s15 is a quicker car IMO but the r34 is a nicer drive
brett! long time no hear buddy
yeh ive thought about doing the R32 or R33 GTR but i really dont want an older car plus im so over the amount of 33's and 32's everywhere
but mainly insurance is a bitch haha
and yeh nah not into the rex's like i used to be haha
im thinkin about checking a few car yards just to see whats out there and what prices i can get but everything is such a rip off in perth
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
