hey guys havent used the forum in ages but i need some urgent and honest opinions
finally sold the non turbo R33 which ive had for 4years now and its time to upgrade
and im still trying to decide between an R34 and an an S15 i know this is a stupid question to ask in a Skylines forum but i basically wanna spend around the mid 20's on it and im after something with low k's and some minor mods
so first question is R34 or S15? i originally had my heart set on an R34 but seems i can find a cheaper S15 with less K's for around the same price
but im guessing an R34 would be a better drive and more power?
i imported the last car and am still deciding on whether to import again
im not the most patient of people so waiting 8-12 weeks will kill me plus ill be without a car and have to organise a rental
but i believe ill save around 5grand after looking into it
so second question is import or not? ive also found that there a fair few cheaper ones over east has anyone bought a car over east?
any help would be muchly appreciated thanks!
https://www.sau.com.au/forums/topic/168639-time-for-a-new-car/
hey i had this problem when i was looking.
but my opionion i think the r34 would have lower k then a s15 would because its newer but not sure depends but u can get some from dealers that are freshly imported but they already here so u dont have to import ur self. it also depends on waht u want the car for the r34 will be heavier then the s15 but in the end its up to u. but u should be able to pick up a nice car with mods botht the r34 and the s15. so i say just keep looking and ul find a winner. hope this helps
S15 FTW!! awesome handling and SR20 midrange torgue!
Personal preference mate but they both have strengths and weaknesses ie:
S15
+ awesome midrange torque
+ very good chassis balance, handle great
+ look like sex on wheels
+ parts can be cheaper
+ flat thirteens should be doable on stock turbo
- six speeds break :)
R34
+ bigger car
- heavier front end dulls handling
+ sounds awesome
+ tougher driveline
+ wishbone front end
"but im guessing an R34 would be a better drive and more power?"
not much real HP difference when modded(stock turbos)
plus the vehicle weight. . .
that help?
"weird i thought the only difference with spec s and r was sun roof and 6 disk stacker. and the spec r was a little slower due to extra weight?
unless the jap versions had more power and the aussie delivered as the same"
AUS SPEC S = 200 hp S14 config motor
AUS SPEC R = as above but more trim options
JDM SPEC S = N/A Motor
JDM SPEC R = 250 HP BB turbo, bigger injectors, tune etc.
This is the general consensus, but there is still arguement about it. . .
so if you get an imported JDM R spec you get a better motor and the possibility of plenty of JDM trim options
the debate continues!!
there are bugger all r34s in dealers at the moment it seems , budget 30k for a nice manual coupe
aus spec s15 does not quite have a s14 spec motor , ecu and turbo is different . some aus s15s have bb turbo also
basically though 147 aus vs 185kw jdm
the s15 is a quicker car IMO but the r34 is a nicer drive
brett! long time no hear buddy
yeh ive thought about doing the R32 or R33 GTR but i really dont want an older car plus im so over the amount of 33's and 32's everywhere
but mainly insurance is a bitch haha
and yeh nah not into the rex's like i used to be haha
im thinkin about checking a few car yards just to see whats out there and what prices i can get but everything is such a rip off in perth
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
