Stolen R31 Skyline Silhouette - Have You Seen?
Hey guys. Just got back from Melbourne.
Here is the roundup. Car is in Ok condition. It has a smashed front windscreen, the drivers lock has been ripped out and my left rear white wheel is missing. It looks like they took it for burnouts and when the tire blew, just chucked the rim somewhere. Also the fuel cap is damaged and they had stuffed newspaper down the tank. I guess they were going to torch it later in the night if it wasn't picked up.
They also smashed up the dash and the engine has an oil leak from the exhaust side. I hope it hasn't blown a head gasket or seal. Not sure what to do with the car. Depends on how much the windscreen is.
a20089 - I own you a case of beer or something. I will sent you a PM.
Thanks for looking guys. The police weren't much help and even after I rang them and told them were it was and could I take it, they told me I had to wait. They then organised their own tow which cost me $265 to get from the corner of Fyshwick to Fyshwick and didn't inform me until I rang them back to find out what was going on.
Cheers,
Brett
Sound like the bastards that took my last car.
Glad I could assist, you can pay for my pizza next pizza night :-) Hint Hint Veilside :D
One good thing this comunity has done for for a fellow liner owner, let it not be the last.
Cheers,
Cheers,
Paintball and pizza for the next ACT SAU get together :D?
Good to hear you got the car back, now comes the fun part of finding what those bastards have left for you and what they have taken
Hey dude,
I got a few parts, PM me what you want.
Even got a front windscreen if you pull it out yourself.
Otherwise i might buy you car.
Hello
I had another look and it is not as bad as it looks. The biggest pain is losing one of the GTS2 mags. I have another set full set of locks already (just need to TIG up the boot hole) and I got quoted $200 for a new windscreen fitted. Just need the instrument cluster and handbrake cover. Do you have extras of these that you want to sell? Also, the steering rack is leaking oil, Don't know if you got a spare rack as well?
Goes to show how strong the RB30 motor is. It must have been revved hard to pop the tyres as they still had a bit of tread on them.
All my steering racks leak... I haven't seen one that hasn't(except new/rebuilt ones).
I don't have any s3 silo instrument clusters, whats wrong with it by the way? I should have hand brake covers... what ever they are...
Instrument cluster is smashed and they also ripped out the needles off for some reason. yeah, there is not such thing as hand brake cover. I mean't the gear stick surround cover. I might have access to one of these as well. i will let you know via PM if I need you to look. Thanks for the help.
 Share
    • You need the kit turbo taipan has shown you because that manifold ia designed have side feed injectors
    • @johnnysr22 did you end up installing the little screen thingy and did it work ?>
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
