Guys,
I know a fair few of you have Wolf in your car. I just got mine installed 2 weeks ago and have been enjoying it thus far. I know I could go an annoy Steve, but seeing as I am at work, and all of you are net jukies, I thought I would ask a few questions:
1. Boost control - how do you lower/raise the boost?
2. Closed loop - anyone running it? If so, how is your's setup?
https://www.sau.com.au/forums/topic/16865-wolf-users/
Hi, I've had my Plug'nPlay Wolf in for quite a while, and Steve is setting up the boost controller on Wednesdy night, I have previously been using my EBC. It can be setup in a couple of ways I believe, user defined via hand-controller/laptop, hi-low switch in auxillary input, or fully controllable via a potentiometer.
Hope that helps.
https://www.sau.com.au/forums/topic/16865-wolf-users/#findComment-347612
Gav - yes have it plugged in and running well, just installed a new fuel pump (Bosch 040) so I am taking it back to do a few runs on the dyno to see how it has affected fuelling.
Steve - yeah I have the manual, just not sure how to raise/lower boost. I imagine I have to play with the valve duty cycle etc?
https://www.sau.com.au/forums/topic/16865-wolf-users/#findComment-349810
