hey
i bought a gts4 motor to put into my r33 gtst i still wanna run rwd
i was unawear that it was a s2 or at least it is a lil diffrent to my engine and mine in a s1
i was under the impression i could remove the sump and trasfer case and put the standard sump on but the bolts a alot bigger on the sump and wont do up
- would i be able to fill the holes and re tap them to teh sizes needed
-also being a s2 motor (thats if it is a s2 motor) can i remove all wiring and coils and put my wiring and coils in and still run normal
the fly wheel is alot thiner than mine
im doin this as i have taken the motor out of my car and putting a standard one in but couldnt find one at the time for a good price
can anyone help me please
atm i have stripped it back to nothing only internals head is on and im about to change sumps any help would be great
https://www.sau.com.au/forums/topic/168654-gts4-motor-into-a-gtst/
mm... your wording there isnt too good :sleep:
Is the GTS-t sump bolt holes bigger or smaller than the GTS-4 sump?
Either way, you either mod the GTS-4 sump and lop off the diff (no great drama for a half decent fabricator)
Or just mod the GTS-t sump to suit the holes.
I wouldnt be playing around with the block, i'd be playing with the sump
the gts4 sump holes are bigger than the gtst ones
would the volume of oil in a sump of a gts4 be any diffrent to a gtst sump ??
cause i was just goin to do wat you said chop off the side and fab it up
Isn't the gts4 r33 an non-turbo motor? ie higher compression and a few other changes standard?
at first i thought it might have being but the seller assured me it was a turbo
when i got it i checked for turbo oil and water lines and they were all there so im guessing it is
can someone correct me if im wrong please
can someone check the engine number for me ??
Edited by teazn_r33
So drill the GTS-t ones out, and fit it.... Or is that not an option?
I havent seen the two side by side so dont know if its an option
It would be the cheapest if it is though.
If not, just lop it off as i would imagine it to be the same/similar to a GTR one.
Im running a modded (diff removed) GTR sump on my RB26/RWD and capacity is little to no different im told and its going to be predominately circuit driven :sleep:
hi,
when we swap 4wd engines into rwd cars here -- we just cut-off front diff part from 4wd sump. already done this three times -- no problem.
enr33 never was a turbo, maybe your engine is from first generation wgnc34 stagea?
to swap s2 engine to s1 car you have to change ignitor (there is no one @s1), coils, maf, tps. If you are really unlucky and you have latest s2 with hitachi CAS (black plastic case) -- then you have to change CAS and exhaust camshaft.
to quote your link.
"Next was the RB25DE, a 2.5l engine with 190hp at 6400rpm, powering the GTS25 and GTS4." note gts25, not gts25t.
Doesn't change anything for you, just look in the stagea part of the forum for more specific information on the motor that you have and what you have to change for fitment..
Personally for the sump I'd be doing what r31nismoid and stronzo suggested.
Edited by heller44
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
