  • Replies 40
The way I reset the ECU is probably a bit of over kill...
1. disconnet battery
2. pump brake pedal
3. turn head lights on (or turn them to the on position)
4. leave car overnight...
That should be more than enough to drain all electrical power from the car.
https://www.sau.com.au/forums/topic/16867-turbosmart-bov/#findComment-349543
i got a blitz DD Super Sound, put on just last week, they workshop resetted my ecu and it has not stalled once on me :D
my mate has a GFB Bovus Maximus and again resetted the ecu, and it does not stall at all :D
adrian :)
https://www.sau.com.au/forums/topic/16867-turbosmart-bov/#findComment-350001
Guest INASNT
adrian :)
and did u block off your stock 1??
if not then the blitz 1 wont be working properly!
I drove around with the same blitz crap for 1 year and it pissed ke right off! It make the car drive like a pig, i went back to the stock 1 when i got my fmic and its so much better to drive without the blitz shit!
https://www.sau.com.au/forums/topic/16867-turbosmart-bov/#findComment-350010
Guest INASNT
Originally posted by JNR24
I gota GFB atmo BOV, just reset computer and no problems with mine!
so if i chuck a t88 turbo on my car without changing anything and reset the ecu the ecu will know i installed a t88 turbo so it will change all the setting to run the t88 properly??
I DONT THINK SO!
https://www.sau.com.au/forums/topic/16867-turbosmart-bov/#findComment-351296
    • PULSAR PSR2860R 0.86A/R or 0.64 GEN 2 Turbocharger Both are -50*67mm 8 blade billet compressor wheel Cheers
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe.....EDIT... nope, the Kraken is a cast jobbie, the REv9 uses welded up stainless, plus $8000 AUD before shipping, installation and tuning) Where else in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit that Pulse fitted, and it was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
