Cylinder 5 in my car melted a plug. got it checked out, compression test, told compression is really low and that more than likely piston cracked. Im sure this problem occured after my fuel pump stuffed up as car was runnin lean. i have to drop the motor and tear it apart to find out exact problem and extent.
so anyways im asking how much will it cost approx to get something like this fixed?? and is it worth fixing or buy another motor.
https://www.sau.com.au/forums/topic/168671-cracked-piston-on-my-r33-gtst/
yeh pistons, bore it out, head gasket, new bearings, new cam belt, idler and pulley, gasket kit, water pump...
theres some basics.
i weighed this up when i blew up my missus wrx (and yes i rebuilt my r33 aswell lol), the thing with a second hand engine is you dont know the history of it and how long before something goes wrong. rebuilding costs a touch more (shop smartly and do research) but you have a mega strong engine and you know exactly whats happened to it. the piece of mind that you have a mega strong brand new engine is very comforting.
mate, how long is a piece of string. how much money you wanna spend, power goals etc. there's no perfect answer.
if you just wanna get it runnign again, a pallet motor will be the cheapest - maybe 2k from the wreckers. Everytime i'm at the wreckers, the motors seem to be in crap condition though - all dirty, been sitting outside not covered etc.
BillyE here on my bros username.
We will take the motor out ourselves, strip it to just the full block and then have someone work on it.
From what we can tell her, it seems the best idea is to rebuild it, really not interested in purchasing another motor at this stage.
for a realistic budget, say 2-3k, is it possible to get some forgies, after market head gasket etc, or should we be sticking to a standard build.
Say the budget is 2.5k, what can we get out of that in terms of rebuild?????
Thanks for your time and appropriate responses in advance.
ahhhh...
wiseco pistons 1100 del,
trust head gasket 440,
acl race bearings 140,
cam belt 110,
idler pulley bearigs 110,
full gasket kit 200-300,
water pump 40,
thermostat 70,
thats what i paid for my parts than you have machining costs too
f**k all?
You well get the block decked and head machined right? Do you want to use this chance to get more power from the engine or just rebuild it stock so it works? To crack test and machine the head your looking at 1k, then you got to get your parts.
Head gasket
Pistons and Rings
Rods
Bearings
Idler and Pully
Adjustable cams? Is it a S1 or S2 Skyline? S1 only need the 1 aftermarket cam gear and S2 have 2.
Timing belt
Etc etc
You will need to make a decision if you're buying stock parts to get it going or forgies to make it stronger and get a bit more power and go faster. Speed costs money, how fast do you want to go?
Then you need to allocate money for when it stuffs up. You'll need a service not long after it is back in and running, new filters, oil obviously, and for Motul you could be looking at another $250 if you want engine and box oil.
Put it this way, I put aside 5k for my rebuild back when my engine blew up in May 06, so far I have spent 5k x3 + some and the car still isn't on the road. Choose who you get to do the work carefully and only take it to a reputable dealer who has experience in what you want done. It might cost more initially but in the long run it's a God send.
Good luck with it!!
f**k all?
Head gasket
Pistons and Rings
Rods
Bearings
Idler and Pully
Timing belt
Etc etc
Good luck with it!!
ouch phee thats bad, 5k x3....you must be pissed lol i prob spent 5k all up and that included suspension, turbo, engine lol, helps when my rebuild cost me $500 labour but haha i love knowing the right ppl
Thanks for rubbing it in :laugh:
Where are you located? I might know a few good w/shops in your area that you can get advise from.
Unless you're aiming for over 250rwkw, I'd say 2nd hand motor would be the best option. I dont' like the idea of buying questionable condition motors from the wreckers.
Having siad that though, they do have WARRANTY!
many people have no dramas with the stock motor at 250 rwkw. cheapest option and it'll have you running in almost no time.
Just the bare bottom end inc. forged pistons, crack test everything, slightly more expensive king HP bearings, block decked, rods resized, oil drain mods, gaskets, mls headgasket & heinz balanced cost me 3.6k. I was quite happy with that, probably similiar in costing to yours + I had a few extra bits done that really didn't need doing. :dry:
cheap option, you maybe able to drop the oil sump, pull out the piston, and replace the one. if its still a bit low on compression, sell it and get a new car :dry:
i guess thats one reason why i compression tested my last car before i bought it :)
my mate blew something in his sr20. replaced it to similar specs, and his car was never the same again , just didnt have the same power. has happened to another friend with a different turbo engine.
i spun a bearing in my sr20, spent a bit for a built forged bottom end, put it back together and it was laggier than before, -i didnt have the money to go all out with a better turbo etc. i sold the car soon after fixing it.
my point is, a lot of money is at stake, you have a lot of options. explore them, get estimates from shops, look at your funds and goals
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
