can anyone spec the properties of what engine oil, diff oil, lsd oil,gear box oil, coolant i should be using on my r33 gtr. and what s the small fluid tank in the boot on the drivers side for and what fluid should be put in there? tryed all the manuals but came up with nothing so far so any help would be appreciated.
https://www.sau.com.au/forums/topic/168706-what-oils-and-fluids-and-for-where/
I use:
Engine: Castrol Edge 10/60
Front diff: Castrol SAF-XA 75/140
Rear diff: Castrol SAF-XA 75/140
Transfer case: Castrol Transmax Z ATF
Gearbox: Castrol Syntrax 75/90
Brakes: Castrol SRF
Clutch: Castrol SRF
Power steer (HICAS): Dexron III (generic) ATF
Attessa: Dexron III (generic) ATF
Redline light-weight shock-proof for gearbox, absolute must for shit synchros in skylines
Dont belive the hype..
Had some.. got rid of it.. sure it makes your gearbox feel better.. but so does any other gearbox oil
you are most likely replacing some shitty old oil.. anything is going to be better
