hey guys i have an 97 stagea and im wonderig what the norm is for idleing on the highway? at around 100 to 110ks mine sits on 3 grand.... just seems to high.... feels like the auto needs to drop back.
have had it to the auto shop and hooked it up to the scanners. everythings doing what it is supposed to. was told that it could be the tps switch that might need adjusting. adjusted it in increments to no success. weird thing is it has an open centre in it?? thought it would run an lsd???
any other ideas.???
also the 4wd doesent work. havent even looked into this problem yet. where do i start????
https://www.sau.com.au/forums/topic/168724-idle-at-100k/
do a search in the general automotive section, I remember seeing a DIY in there about reseting idle and it had something to do with an air bleed on the plennum.
Mine (was) at 2500 - 2600 at 100kph and I have 17" on 45 series and a stock as a rock auto.
https://www.sau.com.au/forums/topic/168724-idle-at-100k/#findComment-3117996
thats a real worry - has the attessa pump got any fluid in it?
It may just need bleeding, but I would have a close look at it if I were you. Running the pump and/or transfer case dry (if that is the problem) can get very expensive. Usually, the only way to get a stagea to run in RWD only is to drop the front driveshaft out - the old "just pull the 4WD fuse" doesn't really work and can actually cause damage if left like that.
https://www.sau.com.au/forums/topic/168724-idle-at-100k/#findComment-3118075
Mines auto and sits just on 2500. Worked out it does just on 40k/1000 when the converter is locked up. Am running 17"
225/50/17 Federal595'
Just a further on this.
I got wacked twice for "exceeding the speed limit" but concluded the checking methods were suss. No charges.
I run a general rule, 10, 20, 30, 40 kph/1000rpm in 1st, 2nd 3rd OD. Around the Mountain (town) I now popthe OD to OFF.
Keep to 2000 and no dramas. Thats what I do.
It is interesting to see that there is quite a difference between various owners. you would have to check on the final drive ratio
and the actual diameter of your wheels to see exactly where each vehiclewas at. And if auto that the converter actually does lock up.
My old RMR30 (used to) did 50k/1000, locked up. Couldn't get her started for her final triptoday. I think she knew.
She used to peak about 4250. But the RMR30 were a very slippery vehicle and had one of the lowest coefficients of drag
factors of most cars of its time. It is what made them fast, not quick, fast.
So there are a lot of factors that govern the revs/km. All aspects have to be taken into consideration.
Owning a NIssan is such fun. I have five. Well four after today.
https://www.sau.com.au/forums/topic/168724-idle-at-100k/#findComment-3119526
    • If there's a next time, next exit after mine is Costco 😛
    • OK. But what about parts of the block that, when assembled, were twisted into a position that pushed into the void space, which, when disassembled, then released that force and opened back up, thus putting the grout into tension? Would effectively just pull the cast iron off the grout at the interface, leaving a tiny void and benefitting not much at all. Swings, and roundabouts. It's like putting something tiny into the fleshlight and finding out you needed a smaller one, to perhaps follow your area of expertise.
    • Nah. You buy a kit that has shorter tubes.
    • I didnt present too many conclusions because I wanted your opinions and feedback based on your own experiences. I don't know the exact material, but it is similar to concrete and therfor only has valuable strength in compression. The forces on the set material once the head is removed would mostly be in compression since the grout wants to retain its shape and the block wants to return to its relaxed state since it's still within the elastic region. The grout would theoretically make the block more rigid. The exact amount would take a better setup on my end. Thought experiment: Instead of aliens, twist your favorite fleshlite. Now fill it with grout and allow it to sit for a week. Now try to twist it again. Observe what you see. Now get your other one and blow into it. Observe what you see. Now put it into a can and fill the space between your fleshlite and the can. After it sets blow into it. Less movement in torsion and less expansion i hope.
