  • Replies 81
Posted Images
Boot trim.. the part where the bootlid latches into.. black plastic bit across the back
Can take a picture if you arent sure what i mean...
p.s. be careful taking it out.. it snaps really easily :laugh:
Im in Viewbank too.. which is nice and close to eltham
Passenger seat??
Passanger seat is pushed in on the headrest from the roof. not sure how it will come out when i cut the roof off. i might cut it off tonight and have a look.
the plastic around where the boot latches is already cracked... apparently they crack easily? haha
Looking for the e-brake cables! And will pay ASAP with PayPal or whatever you want......Please let me know. Thanks.
Well, I have an S14. S14s can use the R33 e-brake cable setup, and S13s need the R32 or Z32 e-brake cable setup. I happen to have a set of Z32 e-brake cables, but they are WAY too short for the S14. But they fit perfect on the S13. Interested lol? Maybe a mutual swap and I will pay you still........
do you have the bracket that supports the exhaust, connecting from the gearbox crossmember? see pic, what i want is circled red
thanks
ps ALSO WANT BOOT CARPET?
yeah i have that... how soon do you need it?
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
