my mate got his 180 tuned by adam at jem and hes running a power fc and he like to do very safe tunes so id recommened him
also have another mate that has a ae86 turbo tuned by adam and also did him a very safe tune
Ben!
My car was tuned at unigroup - and alot of other members here have had their cars tuned there.
I am really happy with the tune so far!
12psi made 195rwkw but safely
only time I have had major knock was on the track and a hot day!
so other than that - she's been good mate
Yavuz and Adam are both very good tuners. I have nothing but praise for Unigroup as do many forum members over many years.
You will be happy with either and they're both very nice guys.
  DiRTgarage said:
Post of the thread..."thats gold"!
Damn it I knew I should of done more random look at me threads with my motor in my falcon ute or look at my shiny new cooler piping through out the forum so people didn't forget me
wait wait I'll start now
Cover of Zoom :)
  benl1981 said:
I would havehoped the tune would be safe for the track and hot days also. Have you had it back to them to sort it out?
Cheers
When Im out there I always use low boost to keep it safe anyway - dont have dramas with it then, just on the higher boost setting - with a shitload of heat thats all.
There was one bad batch of fuel which sucked also.
I did DECA on the weekend and highest knock was 22
I have spoken to Yavuz about it and he is more than happy for me to bring it in when I can
I just dont have the time and its a very minimal issue!
Cover of Zoom :)
:thumbsup::wave: fully sick got to love that :wave::(:thumbsup:
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
