i am inKuala Lumpur at the moment..
anyone from here or along those lines.. know if there is anywhere to buy bits...
tail lights.. kit bits... dash kits.. any sort of rice at all..
holla back i am here till the weekend..
Yeap go to Sunway. There are at least 20 car related shops there. Also if you have the time you can head over to SS Racing nearby this place called OUG. If you were to go to Sunway, ask anyone there and they'd be able to direct you to SS Racing which isnt far from Sunway. They have a very large selection of parts both 2nd hand and brand new.
when I was there, I went to a place called Brothers car parts and accessories.
they had a huge selection of car parts and audio gear. Heaps of rice parts as well.
Haha Brothers is sort of like Autobarn here. They have a lot of cheap rice parts but they are pretty poor quality and i doubt they cater to skylines besides some universal stuff. I personally wouldnt recommend going there coz you may be quite disappointed haha. They're ok for audio gear though.
Sunway ftw. Beware though, car modification in Malaysia is expensive, therefore don’t expect to get quality bits cheap (as I found out), you will be disappointed. Nengun / Greenline is way cheaper. Went to Brothers also, looks good from the front…lol, inside lots of crap everywhere, mainly just tacky stuff to bolt onto your Proton (of which there are eleventy billion of in KL).
I'd say you're back but don't waste your time at Brothers. i went there last time I was in KL and it's exactly like supercheap, but much much worse. There' not one real performance part in the shop, all "Monza" and "Type S" brand type stuff. Audio might be ok there though. There really isn't much quality car parts to legitimately get in M'sia unless you know people :)
It really depends, where you look. There are places in malaysia that does some serious mods and stuff. You just need to look around. Pick up their local car mags that are in english, and you'll get quite a good idea, loads of adverts, some with prices to boot. So you can roughly gauge how much after exchange rate.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
