aircon is not a issue in this case. i wouldnt of thought the oil pump as any thing to do with the balancer as the two are not connected mechanically.
the car parts stores in bundaberg are useless, they just looked at me blankly when i asked for a set of lifters for a RB25, so not even going to bother about the balancer.
just wanna know if it will be right to use temporarly so i can see if its the noise i have and until i can track down a proper one.
  • 3 weeks later...
not if you want to run a v belt for the aircon. the 30 ones are smaller aswell and less suited to revs. bigger the better or by by oil pump. i can see you went to repco or something and pulled out the ol mckay balancer book lol.
are you sure this is correct, coz i went out and bought a 25% underdriven power bond balancer which is obviously much smaller and is ment to be a lot better than the stock ones due to its smaller size. and all the power bond balancers on display for drag etc were much smaller than normal hence it must be better??
    • You need to jam something inside it to stop it collapsing. A washer, a spacer, a something. Needs to stay up at the fully pumped up height. I still say you can measure centrelines with a collapsed hydro lifter. Whatever max lift is will be max lift regardless of the state of the lifter.
    • Yeah, I've been watching him since the first 4 posts all arrived.
    • Quick update Guys , managed to get the water pump replaced . I first my mechanic went back and forth with Nissan AU (4 weeks) and they weren't much help, at the end they noted something about not supporting imports. So I soured the part myself from Japan. If anyone has similar issue here is the part numbers  Genuine Nissan PUMP ASSY-WATER - 21010-4HK0E Genuine Nissan Gasket - 21014-4HK0A  Cost me about $230 including shipping (I had in within 10 days thanks to Blackhawk in Japan)  They are basically the same as the Red Sport or even the new Zed - here is link to a supplier in US who helped me confirm the parts matched  https://www.z1motorsports.com/water-pump-fan-and-thermostat/nissan/oem-14-20-vr30ddtt-water-pump-p-10167.html You can change it yourself if you like , but I had my local workshop do it , it was about 5 hours of labour.  Cheers  Pac
    • +1 for these guys, they just made me a custom muffler for another car (old Merc V8 not a Skyline) and they are legends to work with and do very nice work at a reasonable price.
    • Alright well now I’m confused, some people saying yes and others saying no. How would I modify my hydraulic lifter? Iv already pulled them apart to clean them so I know how to do that but what would I change inside the lifter to make it solid? And how would that work with clearance between the lifter and the cam?
