The Hobart Sporting Car Club and JDS Auto Imports are proud to bring you Round 2 of the 2007 JDS Auto Imports Tasmanian Drift Series.
WHERE: Baskerville Raceway
WHEN: Saturday June 16
TIME: Gates will open to spectators at 8am
The course of the event will be as follows:
09:15- COMPULSORY drivers briefing (if a driver does not attend this they CANNOT drive)
09:45- Observation run behind course car
10:00- Practice runs
11:30- Qualifying runs
12:30- Lunch Break
13:00- Top 16 Battles
14:30- Expression Session
16:30- Conclusion of events
LICENCE REQUIREMENTS:
A CAMS 2NS or 2S licence is required.
GENERAL REQUIREMENTS:
- ADR approved helmet
- long sleeve shirt (flame retardant)
- long pants (flame retardant)
- appropriate foot ware (doesn't have to be race boots or cover the ankle)
- fire extinguisher and clasp (MUST be a metal bracket and bolted to the chassis)
- battery and tow indicator (stickers)
- secondary bonnet restraint
- and a general road/track worthy car
NOTE: The full scrutineering requirements are available HERE
ENTRIES:
Will open on 21 May 2007 and will close on 16 June 2007. The entry fee will be $135 if received by 13 June 2007. The entry fee for entries lodged after 13 June 2007 is $160. The entry fee includes a $10 loading for a compulsory sticker pack,
Entry forms must be completed in full, accompanied by the entry fee and lodged with the Secretary of the event.
Entries should be forwarded to the event secretary, GPO Box 1155, HOBART, Tas, 7001.
Cheques and money orders should be made payable to HOBART SPORTING CAR CLUB
Entries paid by cheque are not contractual until the cheque is honoured.
The event will be limited to 50 starters .The organisers reserve the right to refuse any entry without assigning any reason therefore - NCR 83.
OTHER INFORMATION:
- There WILL be a tyre fitter in attendance on the day, tyres can be changed at $10 per tyre
- There will be food and drinks provided on the day by the parents of a few drivers. Hamburgers, sausages and soft drink will be available throughout the day.
- Any driver(s) and or spectator(s) will/can be asked to leave the track if found not following instructions of the day or found to be endangering themselves and others.
This can and will result in the person being banned from the track and future events.
Any queries dont hesitate to contact me.
Ben
Edited by tas_180
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
