Sorry for the dumb questions.
I'd like to know a good place to spray full kit and approx cost.
Thanx in advance
Erik
there is a workshop thread think it is a sticky that has all recommended workshops( http://www.skylinesaustralia.com/forums/in...howtopic=141454 ). I got mine sprayed at Crowly smash repairs if you call ask for brett he is a helpfull person and gave a good price and the final job was well done.
Edited by phenline
i can recommend Holmes Panel and Paint in Byford
Holmes Panel & Paint Smash Repairs
Lot 12/ 797 South Western Hwy Byford WA 6122
ph: (08) 9525 1224
they did the smash repair work on my excel and it was friggen awesome
might not suit you due to where you live, and they tend to be fairly busy
  • 5 months later...
Can precision fit and / or respray front bumpers ...along with other bodykit bit and pieces already on my R33 GTS-T? ...wing mirrors, rear skirts, rear wings etc?
I've just bought this car from over East ...and the R400 bar is generally rooted ...and a few bits of the bodykit are badly finished / faded!
Also does anyone here know the BEST place / wreckers to go for well-priced Skyline Parts? ...including interior panels / switches etc?
I'm really after a 2nd hand intact stock Series 1 / 2 front bar ...as the R400 bar keeps scraping evry friggin' thing ...it's too goddamn LOW!
Any help would be MUCH appreciated ...I'm a VIRGIN WA-based Skyline owner!
I'm like ly to be off the PC for a week atm ...so anyone who can offer help / suggestions is welcome to call me on 0404 701 035.
Cheers, MARK
    • Do the R32s run high or low impedance injectors?
    • It may not feel like it to your wallet....but sounds like this was one of those "lucky you did it" rebuilds. Hopefully you have better luck this time
    • It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
