hi all
i got R34 GTT. the headlight is faily clean but i see the yellowy dirty on inside and outside of headlight...
i want it to clean as crystal...... i clean the outside with plastic compound... but still see the yellowysy dirty colour... may be its from inside...
does anyone cleaned the headlight for R34 GTT or know how to do it?
cheers guys!!!
paul
https://www.sau.com.au/forums/topic/168855-headlight-cleaning/
hi all
cheers guys!!!
paul
i have the same problem with my r33 gtst i asked around for some one to clean it and they wanted $100 bucks to clean each headlight i told him to take a jump.
i also asked autobarn and they suggested some headlight cleaner for about $20 didnt really see a result.
You can use Brasso to polish, then finish with meguires plasticX.
Although if the problem is IN the plastic and not on the surface of either inside or outside and its faded to a yellow, then there's nothing you can do.
Polishing merely just removes the majority of the hazyness and the scratches that cause hazyness and makes it alot clearer.
It's kinda like glass thats made with tint inside it as part of glass. Rub all you want but its still gonna be there.
If your really concerned then buy new lights :dry:
I use meguirs (sp) cut and polish... worked a treat :)
if you want ot clean the inside, you have to take thel lights out, open them up (oven preheat to 200, turn OFF, 15 mins in, pry apart) then put them back together with some sikaflex...
yeh thats why i use polish/wax it keeps them clean for a while, i mean the dirt or stains if u like, dont stick to the surface, because the wax and polish doesnt allow it... i havent had to clean my headlights for over 3 months...
Yes the brand is mothers, Product plastic cleaner, ive been told the use it to remove light scratches from glass as well. super cheap sell it :D
Covered b4, search button is your friend. Well coz im nice here's the direct link. http://www.skylinesaustralia.com/forums/in...showtopic=16255
Get some kerosene or turps and pour some into the light and shake around then tip out n let evaporate. Doing this is also best way to get an moisture stuck in there out. But if there is moisture in there u may a crack somewhere!
Sounds harsh but seriously this works...try it on some other clear plastic if you dont believe me.
- Wet some 2000 grit wet&dry sand paper and evenly sand up the surface of the headlight
- Clean it off and dry it completely.
- At this point you wil hate me because your light will be all faded and look like shit
- Whip out some standard automotive cut and polish and work it over the headlight
It should come up crystal clear.
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
