where is that place?
please PM me the details of them thank you!
cheers
I'd like to know this too.
I cant imagine it'd be cheap! Those things are made using moulds, i dont think it'd be easy to just take your old lens in, and get them to "knock up a new one" !
I'm sure there is a place ... a spray painter friend of mine told me about it one night when I was winging to him about wanting new lights cause of how dodgy mine are ...
i'll give him a call ... see what he says ... I don't think I'm dreaming it up but you never know :ermm:
Edited by BLK33T
hey ... I spoke to my mate ... the name of the shop is plastiques or plastics <--- something like that ... there in Arncliffe NSW ... he reckons you can get them made up for between $100-150 each >_< (which ain't to bad really)
Apparently you either take your lenses/ lights in to them or send them in and they will have them ready in a day or so ...
hope this helps you guys
Google:
The Plastics Centre Pty Ltd, Arncliffe NSW - also registered as The Plastix Centre.
Plastic Fabrication.
192 Princes Hwy, Ph 02 9599 2499.
Could this be the one? Someone local wana give em a call?
oh my god sorry i've just read the entire thread you guys are retards like unbelievable!!!!
ok, the reason your lights look like ass on the inside is cos of corrosion from the elements, it happens,
drilling a hole in your light will allow more water vapour into your lights thus making the matters worse as condensation builds, not to mention cause your headlight globes to blow due to condensation / oil residue on in your headlight unit...
so please, silicon seal this back up and admit you stuffed up. cut your losses, and start again with a wiser idea...
you must now take the headlight apart,
all you need is 80degree heat and 8 minutes max, check it, you should be able to wedge the tip of a butterknife in to get you started... if it's still not budging, put it back and check, use the buter knife to get you started then gently GENTLY GENTLY pry the unit apart with your big manly hands.
if your oven won't fit it then use a hairdryer / heatgun, once you've got it apart, polish it all up with a plastics polish, make sure you do this by hand otherwise you will melt the delicate nature of the plastic.
once it's clean on both sides, reseal the unit all back together by DELICATELY using a silicone sealant or sikaflex...
don't stuff this up, if you're worried you're going to stuff it up then don't do it... MAKE SURE THE UNIT IS 100% sealed before it goes back, and remember, as with all glue and sealant, LESS IS MORE
DON'T OVER DO THIS.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
    • Well, you wouldn't use 2nd hand bearings out of another engine anyway....so just buying the proper bearings is obviously what you're going to do. The crankshaft would be common. The conrods might be common. There is essentially nothing else you would be able to use.
