iv decided to go for the stealth look , which could require buying black rims - or in my case painting them! now iv had heaps of experience painting body panels etc .. but never done rims before .. now i was wondering is there any special things i should know ?
basically my rims are mono blocks . chrome lip and alloy spokes .. im going to use a spray gun , but the thought crossed me to just buy it in cans ?
here is how i would go about it , if im doing something wrong some one please step in and give me guidance..
1/ clean rims with thinners thoroughly
2/ sand back alloy paint with 200 - 400 gritt - any higher ???
3/ mask chrome lip and wheel with tape and news paper .
4/ apply the base coat , 3 coats?
5/ apply 3 coats of clear .
6/ should there be any sanding it between apart from imperfections?
im going to use acrylic as far as paint / and of coarse clear top coat .
any one think other wise? here is a pic i edited , as rough idea ... excuse my dodgey photo shop work ~
https://www.sau.com.au/forums/topic/168863-im-painting-my-rims-black/
Your not going to use a primer?
I did 2 coats of primer when I did mine before applying the base coat.
The only sanding I did was before applying the primer then cleaning the rim, then sanding between the coats of primer and between the primer and base coat.
As far as applying the base coat and top coat, I did for each: 1 dust coat(light coat) and 2 proper coats at least.
Don't get too enthusiastic with the paint as its easy to get runs.
Masking the rim with tape is a good idea too. Or another way to do it is to smear vaseline on the area's you don't want the paint, and simply wash it off after the paint is dry. Masking is probably easier though.
When putting your wheels back on, wrap your wheel nut spanner head with electrical tape, it helps protect the paint on your rims.
would i really need a primer if im already painting onto a painted surface? i could understand if i were painting bare metal? polised etc? , but by the looks from a small chip iv seen , there is a base black coat and then the alloy colour.....
it could be powder coat not paint,
but just use a spray primer filler to fill any chips, then rub the existing paint with 400 wet dry or scoth brite green.
primer would just allow you to get a perfect finish
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
    • Sell it and buy a turbo version will make it a lot faster
