As some of you may already have read ive been having water temp problems (the stupid gauge flickers under boost) mostly drops to 0 ish and flicks up to 80 etc and just generally being gay, ive open the air valve on top of the plenum to get the air pockets out as well as replaced the coolant etc etc still happening so today i went out and bought a nismo thermostat and justjap radiator to get it done tomorrow, if this doesnt fix it, could it be my water pump?
cheers for any advice or comments
https://www.sau.com.au/forums/topic/168893-could-this-be-a-water-pump-problem/
Flicking guage sounds to me like the gauge and/or temp sensor is faulty.
Best way for you to find out, is to get an aftermarket gauge with sensor. Some of the cheap ones are only around $50. That'll save you pulling out the waterpump to find out that it's fine. You dont' have to keep the guage permanently in your car, but just put it for testing purposes.
That's where I'd put my money. I've had something similar to that on another car before.
Are you actually having temp problems? by this I mean is it just the gauge in the dash that is being dicky? or is it an aftermarket gauge? have you plugged a laptop in and seen what the ECU water temp sensor is reading?
Edit: manwhore beat me to it.. I thought my car was running a little hot as the needle looked like it was sitting a little high, IIRC the ECU and the dash gauge use different senders, I plugged the laptop in and the ECU says it's running pretty much spot on 80deg
Edited by bubba
my pfc had a max water temp of 87 today , i dont think its cooling problems but then again the last time this happened my bottom radiator hose disconnected itself (silicone item as well with heavy duty clamp) trust me its not nice to be stuck on the m5 for an hour LOL just trying to avoid what happened before :D can never be too safe when it comes to these things...
and the radiator itself may have a hole in it as i saw fresh coolant when i checked it near the bottom of the radiator, but then i was told by advan that this could be air pockets in the cooling system, as they fixed it last time, but its started happening again...
i will do the temp gauge as well just to make sure
cheers
You have a wire that is shorting to ground, thats what the gauge will do when shorted to earth. If these is no water in the system the needle will sit down on the big C.
And if its a water pump take my word on it put an electric one in Much simpler to do and cools much better
a wire which is shorting to ground...nfi wasnt happening before, so it must be a wire to do with the water temp gauge then? Theres plenty of water in the system and ive constantly checked the hoses they are fine checked for any cracks etc, checked the hose for the over flow bottle, guess after this radiator install im off to an auto electrician :)
Edited by DaGr81
Sorry,
yer if the wire coming back from your temp sensor to the temp gauge could have rubbed through and if its bouncing around making contact to earth and then bouncing away to open the short will give you the old needle back and forth.
Sorry,
ok ive replaced the radiator (all good temp gauge is now at 68 degrees max) what probably happened was a plug came loose as i took the radiator out some plugs needed to be removed and once the new radiator was in it worked a charm when i plugged the wires back in. Unless ofcourse it'll come loose again later which would suck! but yeah surprised how good the fit of the just jap radiator is, bloody huge as well compared to the stocker, looks good in the engine bay too. Hopefully this wont show up again :D
cheers everyone on your inputs!
68 max is too cool. water temp should be between 75 and 80. ftr a peak of 87 is not high at all. especially if that peak occured after you were stopped, or had shut off the engine, then re-started a short time later.
Agreed, 68deg is too cold.. did you put the Nismo thermostat in? I don't think you would have noticed much temp. drop at all with the new radiator and the old thermostat.. engines don't like to be too hot but they also don't like to be too cold.. poor fuel atomisation etc.
yeah nismo thermo is there, dunno why 68 (but that was checking the pfc hand controller when stopping at a light) oops forgot not 68 max it was at 68 when i looked lol i didnt check the max temp. maybe the fresh coolant? we'll see how it goes over the next few days, it was never about being hot, more the piece of sh!t radiator which was leaking lol as well as the crappy stock water gauge was pissing me off (needle bouncing around when accelerating), plus its a good upgrade for track days etc :unsure:
Edited by DaGr81
It will be the nismo thermostat that has dropped the temp, I would be putting the standard one back in (if it's not FUBAR'd) :laugh:
damn, that means more money lol, guess i gotta sell the nismo one (but are you sure its the thermostat and not the new radiator? it is after all aluminium and huge in comparison to stock item)
The thermostat controls the temperature of the engine, it's set to open once a particular temperature is reached. This means that with the standard thermostat, regardless of how big the radiator you should still be running at ~80deg. The bigger radiator will just allow extra breathing space when the engine is making its' max power which unless you're pushing 300rwkw+ shouldn't be much of a difference, it will also help on those really hot australian days.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
