Guest Malleus
I got mine replaced with bog-standard Nissan Maxima wheel bearings, they're interchangable apparantly. Cost something around $200-250 for the bearings and about $100 for labor (they spent hours trying to get the old bearings out, as the bearings had fused with the casing...much swearing was involved, along with a big hammer)
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-38618
I'm not sure what kind of sound stuffed bearings make. The noise mine makes increases with speed and sounds like really bad tire drone (but isn't). At 40kmh its barely audible, it gets really noticable at 80kmh+. This sound like bearings to anyone?
It all started after the rear right wheel had an unfortunate meeting with a curb, so could be driveshaft or bearings.
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-40402
So do Maxima bearings fit front AND rear? Does anyone know?
Shell, your car has done over 100 k km yeah? My mechanic mate reckons they should be done then.
Prolly get mine done soon-ish ( 57 k km) I've got alot of tyre noise but lately I've been wondering if the bearings are noisy. No grinding sounds though :confused:
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-40418
yep Dino my car's got 120,000 on it poor old girl :O
I'll ask the guys about the bearings when I get her serviced then.
Gradenko, that tyre drone noise sounds similar to my noise. It kinda pulsates though, louder, quieter, louder, quieter....etc. It's hardly noticable though, and some days i don't hear it at all.
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-40619
Yeah, that sounds like what mine is doing - a pulsating drone that varies with speed. I find that its a lot more noticable with the windows up and driving on smooth roads, which is pretty much due to lower background noise.
I'm having it looked at on Wednesday, so I'll be able to get back with whether its the bearings or if I busted a driveshaft.
red900ss, I'll find out on Wednesday about Maxima bearings being used as replacements.
Sorry about hijacking the thread, thejackal!
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-41697
Well, my problem is definantly rear wheel bearing related. Mechanic said that rear wheel bearings cannot be replaced as something in the hub is bent if they start acting up (I probably got the explanation wrong). So no, Maxima parts are going to be no use for rear wheel bearings. From what I understand, rear wheel bearings were never meant to be a servicable part and they only start making noise after a hard impact.
He also said that it won't affect handling (as its a rear wheel) and that theres no reason to fix it... as long as I can live with the bloody drone! So yeah, I get to save some money and leave it as it is, but will be on the lookout for a 2nd hand hub (at the right price) all the same.
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-43029
  • 2 years later...
yep Dino my car's got 120,000 on it poor old girl :mad:
hahaha 120,000k's and you think its old... mine has done 190,000k's and its running fine..
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-1071085
  • 4 months later...
I've got a similar drone from around 70km/h to 80km/h but then it goes.
Rear wheel bearing you think or maybe fron? My passenger side front makes a bit of noise when you spin the wheel when car is off the ground, I havent checked the rear as yet?
It's a bit annoying because it's the speed driven at the most
I didnt think it was a bearing because its only at that small range of speeds and doesnt get noisier when you go round corners...
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-1237333
Some are midas are good some bad. my dad put his van in to one. They replaced the rear brake shoes but couldnt adjust the park brake so it worked. My dad went back with it and they mucked around for an hour or so without fixing it - and with a van time is money couldnt afford for them to stuff around.
I was hoping to get info off other here.
If I jack the rear of the car and put it in 4th and get to 70km/h with wheels off the ground I should hear a dodgy rear wheel bearing right.
I checked my fronts and the passenger one is a lot more free and makes more noise than the drivers side one when I spin the wheel.
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-1237680
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
