Guest Malleus
I got mine replaced with bog-standard Nissan Maxima wheel bearings, they're interchangable apparantly. Cost something around $200-250 for the bearings and about $100 for labor (they spent hours trying to get the old bearings out, as the bearings had fused with the casing...much swearing was involved, along with a big hammer)
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-38618
I'm not sure what kind of sound stuffed bearings make. The noise mine makes increases with speed and sounds like really bad tire drone (but isn't). At 40kmh its barely audible, it gets really noticable at 80kmh+. This sound like bearings to anyone?
It all started after the rear right wheel had an unfortunate meeting with a curb, so could be driveshaft or bearings.
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-40402
So do Maxima bearings fit front AND rear? Does anyone know?
Shell, your car has done over 100 k km yeah? My mechanic mate reckons they should be done then.
Prolly get mine done soon-ish ( 57 k km) I've got alot of tyre noise but lately I've been wondering if the bearings are noisy. No grinding sounds though :confused:
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-40418
yep Dino my car's got 120,000 on it poor old girl :O
I'll ask the guys about the bearings when I get her serviced then.
Gradenko, that tyre drone noise sounds similar to my noise. It kinda pulsates though, louder, quieter, louder, quieter....etc. It's hardly noticable though, and some days i don't hear it at all.
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-40619
Yeah, that sounds like what mine is doing - a pulsating drone that varies with speed. I find that its a lot more noticable with the windows up and driving on smooth roads, which is pretty much due to lower background noise.
I'm having it looked at on Wednesday, so I'll be able to get back with whether its the bearings or if I busted a driveshaft.
red900ss, I'll find out on Wednesday about Maxima bearings being used as replacements.
Sorry about hijacking the thread, thejackal!
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-41697
Well, my problem is definantly rear wheel bearing related. Mechanic said that rear wheel bearings cannot be replaced as something in the hub is bent if they start acting up (I probably got the explanation wrong). So no, Maxima parts are going to be no use for rear wheel bearings. From what I understand, rear wheel bearings were never meant to be a servicable part and they only start making noise after a hard impact.
He also said that it won't affect handling (as its a rear wheel) and that theres no reason to fix it... as long as I can live with the bloody drone! So yeah, I get to save some money and leave it as it is, but will be on the lookout for a 2nd hand hub (at the right price) all the same.
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-43029
  • 2 years later...
yep Dino my car's got 120,000 on it poor old girl :mad:
hahaha 120,000k's and you think its old... mine has done 190,000k's and its running fine..
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-1071085
  • 4 months later...
I've got a similar drone from around 70km/h to 80km/h but then it goes.
Rear wheel bearing you think or maybe fron? My passenger side front makes a bit of noise when you spin the wheel when car is off the ground, I havent checked the rear as yet?
It's a bit annoying because it's the speed driven at the most
I didnt think it was a bearing because its only at that small range of speeds and doesnt get noisier when you go round corners...
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-1237333
Some are midas are good some bad. my dad put his van in to one. They replaced the rear brake shoes but couldnt adjust the park brake so it worked. My dad went back with it and they mucked around for an hour or so without fixing it - and with a van time is money couldnt afford for them to stuff around.
I was hoping to get info off other here.
If I jack the rear of the car and put it in 4th and get to 70km/h with wheels off the ground I should hear a dodgy rear wheel bearing right.
I checked my fronts and the passenger one is a lot more free and makes more noise than the drivers side one when I spin the wheel.
https://www.sau.com.au/forums/topic/1689-wheel-bearing/#findComment-1237680
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
