Hi Everyone
We're conducting a High Performance Training and Track Driving Day at Sandown on Tuesday 12th June
We will be running the day as an 'open pit lane' day, but we will also have 4 qualified (Certificate 3 and 4) instructors with lots of experience at Sandown, (they are all old tossers like me !!).
We also provide lunches, tea / coffee / soft drinks / cakes !!, flaggies and Racesafe medical / rescue crew.
You do not need a CAMS or ASSA licence to participate in our High Performance Training and Track Driving Days
The format we run to is: 3 groups of ten drivers, twenty minutes of track time per hour.
Start time is 8.30 am for safety briefing, track is open from 9.00 am until 4.00pm
We normally charge $335.00 per driver, but we'll let you have it for $280.00
If you would like to come along please let me know via email [email protected] or call me 0413 540 197
Please dont send me a pm.
Regards
Kev
https://www.sau.com.au/forums/topic/168929-trackday-at-sandown-12th-june/
  • Replies 57
Posted Images
Hi Everyone
Regards
Kev
Kev - interested, But can you put down what we need to bring? Ie - aside from a helmet - do we need to prepare the car in anyway? Fire extinguisher etc?
Edit - crap its on a working day.....:)
Damn Kev, you better run a few more of these later in the year, when my car is back on the road. :(
PS: Just out of interest.
Is this event classed as a "Driver training day"? Only ask as Shannons covers accidents that have occured on such events :) . Could be my perfect solution, to get back on the track.
A couple more of these after August would be great! :D
Damn Kev, you better run a few more of these later in the year, when my car is back on the road. :laugh:
Is this event classed as a "Driver training day"? Only ask as Shannons covers accidents that have occured on such events :wub: . Could be my perfect solution, to get back on the track.
A couple more of these after August would be great! :)
Yes Al, it is classified as a driver training day, my instructors are all fully qualified Certificate 3 and 4 driver trainers.
Im guessing guys that if they were run on weekends then none of us could afford it as Kev woudl have to pass on the additional expense of track hire?
Seriously, put in a day of leave. Tell the boss its in his own best interest, if you ever drive company vehicles. I cant see too many bosses knocking back days of leave for "training"
My problem is car, need tyres and new brake pads :) There is 2k there :laugh:
I'm in for this... only issue being my car decided to dump ALL its water on the garage floor overnight... it looks like its coming out from the sump/steering rack area *eeek*.... if its just a perished hose or fitting I'm there! you have a tentative email Kev
My problem is car, need tyres and new brake pads :) There is 2k there :P
damn....so no chance of the weekend track days for a while atleast - will see if i can get the 12th off and head down.
i'm there too bro...sent Kev the email. should be good.
Yeah Chris should be good to get an instructor in the car
car will be fixed in time... I freaked out after I filled it back up with water and drove it to the garage, when I jumped out and popped the hood there was steam everywhere and I'm thinking oh dear... well it turns out there was a pin prick hole in a coolant hard line that was spraying water right onto the exhaust housing of the turbo! interesting way to keep a turbo cool hehe
Guest
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
    • Not in any way a logical conclusion. Also, looking at those logs, I struggle to see how that much oil pressure can go away that fast unless you are sucking air into the pickup. Meanwhile the ECU voltage is chucking a huge wobbly which seems to be tied to the throttle position. 100% throttle results in decreasing voltage. It's a mess.
    • So didn't get around to installing a manual oil pressure gauge and then decided to take the car for a cruisey drive to a cars and coffee and brought the laptop along with to get another log using more gears to see if its an oil pressure issue under acceleration or after. this log has 3 gears of WOT where as previous had 2 and the oil pressure dropped once on the brakes, and the same again happens here which is interesting as it shows it can hold oil pressure while under acceleration but once slowing or just the lower RPM after a pull pressure drops. I will be chucking a manual oil pressure gauge on to confirm but so far this makes me feel it is not an electrical issue. Something else i realised is the pressure sensor also is giving temperature information and the temp stays steady the whole time which makes me feel like the sensor itself is showing a true pressure reading.
    • LOL.... fk...   there goes 25K to make 200kW
    • For sure the later RB26 variants had a different setup (6 cam voltage sender?), but the RB25DE/DET share the same ECU pinout/PCB footprint, and at the ECU plug it ends up being 'throttle sensor in' & 'throttle sensor out' (to A/T TCU) ...you stick a multimeter on these pins and you'll find them directly connected (0 ohms) ; I had an pair of Nissan ECUs on the bench long ago, and I noticed this throttle sensor in/out link, actually linked to an op-amp ...which was unpopulated on the NA board, but present on the T board and I went 'ah-ha!' in some moment of clarity... ...it wouldn't surprise me if they changed strategy here though (in the software and actual monitoring of this signal), because they did with other stuff (A/T signals).. and 0.45v as a trigger point makes sense, as that's what the external TCU units expect at idle ; kudos, thanks for that insight...I suppose it boils down to whether or not Consult can display real time data of that signal's voltage... ...in any event, it presents the same target...ie; rotate TPS unit to achieve 0.45v to suit both ECU&TCU, and where do you goto from there? Just disconnect TPSwitch connector and/or that plus TPSensor connector....or do you go for the throat and disconnect IACV solenoid and see if it still stalls? (probably throws a recoverable fault code and goes for default idle strategy?)...
