Hi i am after a rb26 block standard if possible or a r33 short motor
Thanks
Matt
Matt if you cant find a 26block Benno still has his 25 short motor with parts, might be worth giving him a bell as i think he was after about $500ish for it :)
Whats the ETA on the GTR?
Ben
https://www.sau.com.au/forums/topic/168936-wtb-rb26-block/#findComment-3129886
hey mate i have 2.. i have an rb25det complete engine but will seperate the head from the block but there is damage to the waterpump bracket...$150
i also have a rb25de bottom end but i might want the oil pump off it
$200
both are in good mechanical condition..
here is a link for pics
http://www.skylinesaustralia.com/forums/in...howtopic=164775
i am located in melbourne and will send if need be.. cheers leigh.
https://www.sau.com.au/forums/topic/168936-wtb-rb26-block/#findComment-3153493
i have one asking $2500 needs a bearing (conrod)its complete , like the head still on the bottom end im in melb , sump been taken off for inspection , crank not too bad doesnt need much attention pm me or call tommorow on 0418 170 234
https://www.sau.com.au/forums/topic/168936-wtb-rb26-block/#findComment-3154099
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
    • STOP GOOGLING FAB9 MAKE BORG WARNER EFR KITS FOR THE NC. THEY PACKAGE AN EFR 6758. DO NOTHING ELSE. CAPS INTENTIONAL. THE BEST RESPONSIVE SETUP EXISTS FOR YOUR CAR, AND HAS BEEN PROVEN FOR QUITE SOME TIME NOW. IN B4 "BUT I WANT EVEN MORE RESPONSE, IN A SIMPLER, MORE RELIABLE PACKAGE" WHICH IS A LS.
