This guy will do custom ones,
http://grapevine.com.au/~marzenna/
I think he was mentioned on the forum before - maybe there's some feedback on him so try searching.
$150, or $300 if your changing injectors or AFMs. He says you should dyno the car after you install the chip - sensible advice.
https://www.sau.com.au/forums/topic/168938-niztune-chip/#findComment-3136641
Any tuned chip will give a noticible difference compared to stock which runs rich and has shit timing maps... i had a similar tuned chip in my car for about a year which had a bit of power but ran really rich down low.....
After putting my new turbo, injectors, afm, and all the other supporting mods, CEF11E tuned an eprom chip for me (costing only $50), send it to me, and i put it in and put it on the dyno (normally $50 for a power run but got them to tune my boost controller so it was $150) and the AFMS were PERFECT, the car made a beautiful 230rwkw and CEF11E hadnt even seen the car....
Pretty impressive if you ask me, Cheap as, perfect maps, and ive since done some more mods and he is sending me another chip!
Hes tuning Canberra cars like no tomorrow and a few more sydney cars too!
HAYSEY
https://www.sau.com.au/forums/topic/168938-niztune-chip/#findComment-3137864
hehe thanks for the plug haysey :domokun:
I would just like to add a bit of information and you can choose to dismiss or take it on board as you like.
Tuning an engine is not something to be done with a few seconds thought. your engine is a valuable piece of equipment and needs to be respected. yes you can buy a remap for your car from ebay but it's a bit like buying a kebab late at night when you are drunk... do you really know what you are getting?
There are people that you can go to and get a professional result:
Dr Drift - Melbourne. really knows what he is doing as is a pioneer, has been doing it for a long time and he is a professional from all the results i have seen.
Speedlab - Jeff - Brisbane? Jeff also knows nissan ecu's backwards and has a lot of proven results and is great to talk to.
Toshi - from these forums also has a lot of results and has been tuning for years since the old schooldays of fj20's in japan.
Yoshitokio - from these forums also has some proven results and has tuned 300rwkw+ cars using the standard nissan ecu.
All these tuners will do a top notch job and you can feel safe shelling out a few bucks to get your pride and joy tuned safely and with fantastic results. they all differ from the fly by night operations that sell a one size fits all tune for $80 bucks from who knows where.
I am by no means a professional and tune for the love of results and interest in performance nissans and I am happy to help forum members out. I have a lot of love for the RB as do all the guys listed above. I have no knowledge of the tunes sold on ebay and do not wish to comment on their merit. But ss the saying goes... pay peanuts, get monkeys...
there is a lot that needs to be done right when tuning nissan ecu's.
Is the chip being used the correct NS rating?
Has the TP scale been set to suit your mods?
what has the tp limit been set to?
What has the rev limit been set to?
Do you have any idea what the timing you will be running be?
seriously ask these questions, it's your engine after all.
Thanks for reading :P
CEF11E
https://www.sau.com.au/forums/topic/168938-niztune-chip/#findComment-3138780
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
