Hey guys, just though I’d post up the results of my new tune, just got the turbo high flowed and a boost controller fitted. All the tuning was done by CEF11E on the Autotech Dyno.
Stock engine internals, stock cat, stock dump, stock injectors, GCG High flow RB20 turbo, bigger fuel Pump and 16psi
I'm so happy with the result, and it’s so fun to drive. Puts a nice big grin on my face every time I hit full boost :) .
A very big thanks to Nick for tuning the ECU, Great job man! Big thanks to Autotech, Integra Automotive, GCG and J Racing
Edited by Viper_r32
https://www.sau.com.au/forums/topic/168957-it%E2%80%99s-tuned-a-ready-to-roll/
sounds good.. how much did that set you bak?
It was $3000 to get the turbo high flowed including the labour
$220 for Fuel Pump (can’t remember how much for labour)
$850 for the boost controller including fitting
$350 for re-chipping the ECU and tuning
So allot! But worth every cent.
Glad you are happy with the results paul ;)
there is a dip in power as you can see due to the boost controller spiking and then dropping back down, this is due to still having a fairly restrictive (standard front/dump pipe and standard cat) combined with a super efficant.
As you can see boost comes on in very short space of time and comes on hard. the compressor is only just in its efficant operating range at 16psi and there is a lot left in it.
Paul, I think i have found out what the issue with the boost controller is :huh: I will pm you the details...
We settled with 200rwkw with 12:1 afr's due to still running stock injectors. With a set of GTR's and new front pipe and a cat 220~240 would be realistic
Good figures. Still think you should have gone with one of Slides high flows for about a 1/3 of the price ;)
Honestly I considered it, but I’ve always been the kind of person who believes in “you get what you pay for”. I have always preferred to pay more money for something that I know 100% will do the job I want it to. But by no means dose that mean that one of Slides high flows would not have been sufficient, but as a personal preference I preferred to go Ball bearing instead of Bush and have it done company that has a really good reputation. As the turbo itself only cost $1900 to be high flowed the rest was all Integra’s labor.
Nice work mate. Mine was on the dyno on Saturday and made ~150rwkw, and I know that's fun on the track. You must be loving it.
Absolutely, Nick suggested I take it easy in the beginning to get used to the power. But honestly it didn’t take that long before I was leaving the throttle open on the straightaways. Although I have to admit I was changing gear a 5000rpm as it’s still a little scary to take up to 6000 but a lot of fun.
Hey, Nice effort - 200rwkw is quite respectable from an RB20, Go the R32's!
Can I ask what kind of boost controller youre using?
Ive currently got 230rwkw from mine but all I need is a boost controller to make 260 - 270, Im looking into getting something electronic for under $1000, but I cant decide what to get.
Also $1900 seems like allot of money for a high flow turbo, I bought a GT30 / 71R ball bearing turbo from GCG - thats a 500hp turbo for $1780.
the good thing with a high flow is that it will just bolt back into place no f**king around changing lines or manifolds, or custom piping!!!
The only things that I had to change were the oil and water lines (which came with the turbo) put a right angle silicone bend on the compressor and a 10mm spacer on the manifold (because the turbo so big), thats it.
Anyone who has some mechanical ability could do it.
A lot of people will disagree with me here.
but in terms of boost stability and simplicity i will allways recomend a turbotech boost controller. mine holds 18psi as a dead flat line...day in and out. no electronic parts to fail, be stolen or set.
they cost almost nothing and if you are after a set and forget controller they are simply the best.
Once you start looking at larger capacity engines that spool turbos quickly an electronic item is good to allow boost delivery to be more linear and not come on like a bomb,
there are a lot of excellent boost controllers out there but do not dismiss the turbotech. it is a good simple invention and will do just as good at holding boost at a flat line.
if you want a high and low boost setting these are not for you.
I had a profcb in my car and removed it and replaced it with a turbotech and will never go back to an electronic item :unsure:
Just some food for thought :D
Apexi AVC-R Limited Edition. I originaly purchesed the standered one form Jerry at J Racing. but then Jerry went to fit it, and it turned out to be faulty. So Jerry phoned up Apexi to ask for a replacement, but they dident have any of the standered ones in stock. they said they had a limited ed virsion but it was like $180 more. Jerry told them that that wasent aceptable as it was a faulty bran new item, and he needed a replacement straight away. so they gave me the Limited ED version for the same price and sent it over night. it was fited the folowing morning.
Edited by Viper_r32
that was the main reason i chose to go with a high flow. so if people look under the hood it all looks stock. no probs with rego inspection, police or anything else
Mine is still a low mount using the standard manifold, the only difference you can see is that it doesnt have the heat sheild anymore and theres a blue silicone hose where the metal right angle used to be (see picture).
It passed ACT rego inspection no problems at all, they didnt even notice.
I would love to get an AVCR-II but they are really expensive, do you think they're worth it?
I had a profcb in my car and removed it and replaced it with a turbotech and will never go back to an electronic item >_<
Just some food for thought :wave:
So how do I get and how much is one of these Turbotech controllers?
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
