you can buy mine, $20. Never used, never installed. Didnt want to risk running it with the stock boost gauge so never got around to installing it.
Couldnt be a more simplistic design, hose goes on the 2 ends, turn the knob for more or less psi and lock it on with the bolt >_<
This is the one off ebay aswell, he charges $29.90 + $7.50 from memory so just give me your address and next time im down in Canberra i'll leave it in your mailbox
or if your want a brand new one
http://cgi.ebay.com.au/Turbotech-manual-tu...1QQcmdZViewItem
Edited by Baconer
SOLD! Done.
If I direct deposit into your account would you send it to me via post? I'll pay the transit fee.
PM me...
Edited by Bullet32
haha thats what i was gonna write at first, you can tell he just got pics of the wastegate actuator and boost controller then just connected with lines :wave:
thats a food stain on the left aswell >_<
PM sent aswell
Edited by Baconer
  Viper_r32 said:
Hey guys, just though I’d post up the results of my new tune, just got the turbo high flowed and a boost controller fitted. All the tuning was done by CEF11E on the Autotech Dyno.
Stock engine internals, stock cat, stock dump, stock injectors, GCG High flow RB20 turbo, bigger fuel Pump and 16psi
I'm so happy with the result, and it’s so fun to drive. Puts a nice big grin on my face every time I hit full boost :) .
A very big thanks to Nick for tuning the ECU, Great job man! Big thanks to Autotech, Integra Automotive, GCG and J Racing
Good to see a good looking car get some more berries!
Silly question,but aren't your AFR's in the second pic in the 13:1,14:1 range? Or am I reading that incorrectly?
    • That may not be so tricky with a changeover relay (again, with LED indicator only to reduce load on existing headlight + source)  30 to indicator + globe side 86 and 87 to headlight parker + 87a to original indicator + chassis side 85 to chassis/earth repeat on each corner, sorted, no diode required
    • There might have been some "hard core" decalcification going on in the cells to create that noise As for chargers, I stick all our cars on a trickle charger every few months to "clean out their pipes/cells", the Mrs battery in her Mistsu ASX is still running its OEM from new battery 10 years on, and that thing does alot of short drives, and it can sit around for ages without a good long run
    • I'm not sure the diode only will give the desired result. I'd probably approach it with a couple of relays (And you still might need a diode too!). You need to be able to break the constant feed from the headlight to the orange corner globe when the indicator is flashing. Not knowing which Skyline we're talking about specifically here too (And it may not matter, but I don't know the R34 column switches) you'd likely need to rewire the stalk, so that the indicator power itself no longer runs through the stalk too, as now you need it able to trigger a relay that will break the constant supply from the headlights to the indicator, then you'll need a separate relay to trigger the indicators to come on (Replacing the internal action of the indicator stalk).
    • Weird story from me My Toyota 86 was with Commbank comprehensive but for market value (who they use to underwrite is unknown) When I munted it beyond financially viable repair in 2020, rear end smashed in to the point it bent the rear quarter and roof, they knew I paid $31k cash for it because I told them, they still paid me out $38k, as all the 2017 limited edition variants with typical Km and condition were going for between $36-41k, so they did weird math and came up with $38k I never officially mentioned any of the mods that I had done, but as they were not the cause of the crash they were not fussed at all, the insurance inspector actually asked if I wanted to replace all the mods with the OEM stuff if I still had it laying around before they took the car I still came out of it behind though, because I had probably dropped $20k in it with the suspension (bent after the prang), wheels (bent as well) and "other" mods, that the inspector asked about But still, as the market value was higher than what I initially paid, and they paid out market value To say I was surprised with the outcome would be an understatement  Weird, but true, but probably just lucky with the inspector on the day I guess  Sadly, I don't think if I munted the old NC1 MX5 I would get the same result Meh, pay to play
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
