Here's the plan, in the next 2 months I'll be changing to an aftermarket ecu. Then I'll be on the market for a new turbo. I want 350hp @ wheels, I'd like full boost around 3500. What turbo do you think I should go for? I'll upgrade the fuel pump and put in a nismo fuel regulator if necesary, but I'd like to run on stock internals for sometime, so I need to keep the boost lowish, thinking around 1.2bar max. Most people have been saying the garrett GT30 with an external wastegate. Whats your thoughts?
Muchly appreciated ;)
https://www.sau.com.au/forums/topic/16896-trubo-choice/
  • Replies 56
Clutch is already done, I'm running a 9 puck unit with a 2500pound pressure plate, same unit most of the guys over here in WA use cos we all go to the same guy... Ross @ Perth AutoClutch :) The ecu I go for will run a 3bar map sensor so I dont need a AFM. I have an EBC, as per my signature. I figured the fuel pump would need doing and I might see if a fuel regulator might keep me from buying injectors... but we'll see what happens... how much is the HKS 2835? Isnt the manifold's flange a T28? which means t25 and t3 turbo's only bolt up with an adaptor plate? or so I thought.
https://www.sau.com.au/forums/topic/16896-trubo-choice/#findComment-350280
Guest INASNT
rob
the new 2835 pro s has a t3 flange!
i am spending a little more than normal do i dont just end up with a dyno queen thats a pig to drive on the road. I am getting lightened flywheel cam gears etc as well so it will accelerate better rather than just have peak power which is useless of the street unless u r driving on the autobarns in germany. :D
also u will need 550cc min injectors and a 044 bosch fuel pump or u will have problems of pining and other issues like alot of people on here have!
https://www.sau.com.au/forums/topic/16896-trubo-choice/#findComment-350870
if you want full boost by around 3500 then youll need something smaller than the 2835... as mentioned if you want 350rwhp, full boost by 3500 is a bit optimistic.
im getting a HKS GT2530, for a comfortable 310rwhp (~230rwkw at 1.1bar) i dont see why it wouldnt do 240kw, with more boost (as its been done on a stock RB20 with same turbo)
while the peak power is a bit short of what your looking for, i hear the response and midrange make for a killer street car. Also you can get a decent one 2nd hand from about 1800$ and will bolt straight up. With a RRregulator you can use standard injectors and your internals will easily hold out.
https://www.sau.com.au/forums/topic/16896-trubo-choice/#findComment-352858
Guest INASNT
Originally posted by -Joel-
What about a 2540? they don't bolt straight up but gain a few extra kw at the top end if that is what you are after.
you 'should' be able to make 260rwkw on a 2540 with a real squeeze.
2540 is a shit turbo and would need lots of boost to get 260rwkw.
with the 2530 u will need around 1.3-1.4 bar to get 230rwkw assuming the rest of your system is efficient!
https://www.sau.com.au/forums/topic/16896-trubo-choice/#findComment-353520
So there crap then.. The 2540's get slightly more power at the same boost levels than the 2530 though.
Still 1.3-1.4bar is a hell of a lot of boost in my book.
How is it that Whatsisnames turbo made 240-257rwkw on 13psi??? And thats a custom turbo.. Makes full boost at 3500-4000rpm and is plain bearing.
On a RB20DET the GT2530 with the right support good FMIC exhaust etc will make 220rwkw on 17psi of boost.
I'm starting to think that aftermarket brand name isn't always better.
https://www.sau.com.au/forums/topic/16896-trubo-choice/#findComment-353556
2540's will give the higher peak, but for street its all about average power... A slightly lower peak but with a fat midrange is far superior to a laggier peakier turbo. This has been well covered in HPI. And its been shown that a 2530 will be quicker than a 2540 on street.
INASNT, the 2530 will only need 1.1 bar for 230kw on an RB25, as im told SYDNEYKID has seen. And who are we to argue with him? :O
Joel, as far as the brand name not being better, I would tend to agree, but its been written so many times in HPI from experience, that the HKS stuff does its job EXTREMELY well, and people who have gone the cheaper garret stuff are usually dissappointed when shooting for HKS numbers and response. Thats according to M.Donnon's personal experiences....
https://www.sau.com.au/forums/topic/16896-trubo-choice/#findComment-354169
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
