Hi,
I have purchased pauter H-prfile rods for my RB20DET. But when I looked for ACL racing bearings, it notised that they where some place between 41.961mm and 41.974mm. But when I messaured my rod journals they were 44,96xmm.
Where can I purchase main and rod berarings?
Hope som one can help :D
https://www.sau.com.au/forums/topic/168978-rb20det-rod-journals/
Hi,
Thats what I thought. Just baught 2 sets of ACL calicio coated race bearings.
Thanks,
RB20's do have a smaller journal, CA18 bearings are the same as RB20's but you'll need to buy 2 sets and end up with some spare bearings.
The bearing measurement is the same as the big-end journal? Standard specification bearing thickness is 1.502 -1.506 mm, so 44.96 (big end) - 2 x 1.5 (bearing thickness) = 41.96 (bearing inner diameter / big end journal)
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
