  • Replies 57
that lada sounded like a beast as it took off ;)
iv sent CABIN an email basically saying "WE WANT IN!" making reference to what we discussed lastnight
if there is no response by the time i leave, ill give them a buzz
reason im not calling straight out is i gather the person thats going to pick up the phone will say "send an email, we here only for technical issues" or some shit like that
Final date for getting forms/money in is the 3rd of July
Heaps of time, but none the less well progress like the dead line is earlier to get out placements in
So far MCCR have done diddly squat and theyre looking to get 20 or so cars
Theyre finalising their enterants this weekend
So what theyve been piss farting around with in the last two months, we did in one night lastnight
Lets keep up our progress :D
Can someone please PM or email me with the details of MAS?
As stated way earlier I couldn't make the meeting but wanted in on the stand...
I'm going to QLD for 3 wks come Tuesday but I'll still be on the forums when I'm up there bumming about doing nothing :D
i went to the PCP on doncaster rd... went all round the carpark except for the bit to the left.... lots of rice box hondas and crap but no lines!!!
damn it.... i knew i should have taken andrews number with me :D
Ok, heres the update
I gave CABIN a call and spoke to this really friendly guy Damian.
Spoke to him and ran him down on the ideas we thought of lastnight and he was loving it
What we have to do from here is:
1. Get the forms all gathered up or EACH definant cars thats going to enter
2. Ill give Damian a call Monday morning telling him basically what cars we have in mind to enter
and then it all happens from there :D
This is looking VERY hopeful
Ill get in contact with everyone soon
Im so excited...two drops of pee just came out
Guest
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
