1 bee-r rev limiter 2nd hand
was working in the car it came from at removal but dont really know much about it or how it works . it was doing its rev limiting thing though .
$220
$20 registered and insured posted most places in aus
Edited by arkon
https://www.sau.com.au/forums/topic/169012-bee-r-rev-limiter/
SOME FAQ'S
What is REV LIMITER?
The unique REV LIMITER from Power Builder Bee Racing is a device where a driver can use to prevent a vehicle's engine from being over rev. All parameter adjustments on this device can be made on the fly from the driver's seat. This REV LIMITER is achieved by cutting off the ignition at a preset RPM limit, and by re-routing a fuel dump. An aural feedback of back fire popping sound from the exhaust muffler is the result followed by a fantastic visual of fire coming out from the exhaust muffler tip. This aural & visual feedback are very similar to those experienced in the fully race-tuned race cars .
Is it really safe to use REV LIMITER?
The rev limiter in the vehicle is controlled by the factory ECU by instructing the fuel pump to immediately stop the fuel supply to the engine. Such immediate forced fuel cut is not advisable if it happens frequently as it has damaging effects to the engine in the long run. On the other hand, with Power Builder Bee Racing's REV LIMITER, it actually cut off the engine ignition without stopping the fuel supply to the engine. With this function, over rev limit damage to the engine is prevented, and is a safer way in the long run when the engine is over revved past it recommended RPM limits.
Can I install by myself?
The REV LIMITER device can be DIY installed. It has four wires of different colors that needs to be connected to the vehicle's ECU. Please refer to installation manual for detail instructions.
My car using POWER FC. Can I install this REV LIMITER?
A earth grounding issue has to be resolved if a vehicle is fitted with an aftermarket APEXi Power FC unit. This grounding issue is due to a lack of a ground terminal in the APEXi unit. The REV LIMITER uses the ground signal to cut off the ignition signal from the ECU. Since APEXi Power FC is a piggy back computer, and manipulates the original engine parameters' signals from the ECU before re-routing these modified signals to the vehicle individual engine components, a separate grounding signal is required from the APEXi Power FC. Once this grounding issue has been resolved, the REV LIMITER will be able to function as it is intended to be.
When can a car get the effect of back fire with popping sound from the exhaust muffler?
The visual effect of having fire spitting out from the exhaust muffler every time there is a rev cut when the REV LIMITER is installed is not guaranteed by Bee Racing. This is due to the fact that fire would only result during high engine revving, and when the exhaust muffler is warm up, and also when the vehicle exhaust system is without a catalytic converter. Basically, the unrestricted vaporized fuel supply when ignition is cut off is lighted off when it mixes with the air from the engine air intake in the hot exhaust system. The hot temperature from the exhaust system is the catalyst that ignites the air-fuel combination in the absence of the ignition sparks.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
