up for sale is my pride and joy that ive had for the last 2 years.
its an 89 r32, manual rb20det, which has been extensively modified for both performance and appearance.
the details of which include:
full gold pearl respray thats less than 6 month old
bn body kit
18" rims
r33 brakes all round
dba 4000 series cross drilled and slotted brakes barely even used
hicas steering has been removed and bypassed lines
uat seat covers in black and grey
roof lining and parcel shelf retrimmed in black
sunroof
stereo with replaced speakers
3pt immobiliser and alarm
cruise control
black and orange interior
engine mods include:
full replacement link ecu with laptop control and hardware
r33 turbo
blow off valve
blitz pod filter
gt spec fmic
twin 10" thermo fans
steel intake pipe
adjustable cam gears
255 l/h fuel pump
exedy button clutch
exedy chrome steel lightened flywheel
short shifter
batmbl split dump into 3" stainless exhaust with high flow cat
alloy radiator and and new hoses added
gtr injectors
just had 100k service with timing belt and bearings and pulleys, water pump and thermostat changed
always serviced at 5,000 ks
i have 2 little kids and am changing my life style to suit them, sadly its time for her to go!
price: $15.000 ono
can supply roadworthy certificate neg.
car is on mornington peninsula in victoria
phone brenden
03 59885475
0424 694 654
Edited by fredzz32
https://www.sau.com.au/forums/topic/169034-r32-gtst-vic-drop-to-14000/
This is going to be a little different from your average question to a seller...
How do you go with baby seats in and out of this car? Does it have the seat mounts etc installed still?
I need to try and justify this to my wife... :O
Also do you have any pics of the interior, boot and engine bay? If so can you please send em to [email protected]
at the moment i have 2 baby seats in the back. i have a 2 yr old and a 4 mth old. yes the restraints are still in place.
its fairly easy to take kids around in.
my gf has a wrx hatch and its no more difficult than that!
ill get you some pics when i get home from work this arvo.
no worries mate
cheers brenden
this cars gotta go guys so ill drop the price to $16,000.
i have my eye on a nice forester and need to sell quick!
drives beautifully doesn't miss a beat!
  • 1 month later...
just fitted alloy radiator and new hoses aswell. relisted after family deaths
have had no time to sell. quick sale needed reasonable offers will be highly considered.
HEAPS of money spent on extras.
hey mate, i was assured it was high flowed when i bought it but after seeing photos of others
i think its still standard. in standard trim 3 tuners have said it will make the magic 200 no worries
after my injectors go in and a quick tune of the link.
dynod today made 175rwkw on 13 psi. injectors are at 70% duty so there is a lot
more room to play with.
this car is my daily driver so i had the tune kept conservative.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
