well I cant really see any differences in the S1 and S2 engine other than the coils. I figure an S1 ecu will work fine for a S2 engine. RB25DET. Anyone know if this should be cool?? Thanks :unsure:
Edited by RB30 Ceffy
I've got a series 2 pfc in my s1 no problems I don't think it works the other way around due to the built in igniter required in s2.
Im pretty sure the ignitor is built into the coilpack itself for S2. Ive got the engine running on a RB25DE ecu right now and that has S1 coils and no VVT and it still drives and runs. Its just slow, doesnt know its boosted or vvt. Ive also herd of people converting S2 coils on theyre S1 engines and not changing the ECU. I just used it so I could make sure my wireing was correct. Also I thought the only difference between the RB20 MAF to the RB25 one is an extra ground in the RB20. They have the same maps im pretty sure aswell as S1-S2. If im wrong I would like to know but other than those two things is there any other way a S1 ECU would do my S2 engine any harm? Thanks for the fast reply guys :laugh:
hey mate
i have a s2 ecu running my s1 engine, i havnt had any problems at all
assuming it would work as you stated the ignitor is in the coils not ecu.. cant really think of any differences that would affect it though.. its a gamble i guess
  • 4 years later...
  • 1 year later...
Is it possible to run the S2 motor with all the S1 wiring and ECU?
Transfer the S1 AFM, coils with top ignigter, TPS (throttle body?), O2 sensor? Also can the S2 CAS be modified or will the S1 CAS bolt up?
anyone know the answer?
Have a S1 RB25de with spun bottom end bearing and looking at putting S2 long motor in
You certainly can, I put a S2 RB25 engine in my S1 R33 and used all the bolt ons from my old engine.
works no worries :)
You can interchange the motors themselves (S1 and S2) without a problem. The differences lay within the wiring, throttle body, AFM, coils, and some later model O2 sensors (still wiring).
The ECU's do have their differences however, I've seen S2 motors run perfectly fine with S1 ECU's.
Hope that helps.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
