hi all,
Ive just noticed the last couple of times i drove my car it was difficult to select 2nd gear. the clutch isnt more than 1 yr old and the gearbox was rebuilt 11 months ago. im not too sure if my clutch is on its way out or not. i do drive hard sometimes.
how often do i need to change the gearbox oil and soforth? 5 speed manual r33 gtst. exedy organic heavy duty clutch.
need advice.
thanks in advance :laugh:
https://www.sau.com.au/forums/topic/169125-hard-to-select-2nd-gear-when-cold/
hi all,
need advice.
What gearbox oil are you using?
Could it be due to the weather cooling and the oil thickening?
How old is your slave cylinder? (underneath on driver side of gearbox)
I fitted a new slave cylinder, fresh clutch fluid and had it all bled and it was like I just had a brand new clutch fitted, that's how big of difference it made.
If you havent got it already, try putting synthetic oil in your gearbox. Synthetic oils perform much better a low (and high) temperatures than minerals. I havent had any sticking since i switched to redline light shockproof in my tired old box. Shockproof is not suitable for a recently rebuilt box tho.
gearbox was built from scratch 11 months ago. i'l change the gearbox fluid and clutch fluid n see how it all goes
11months is nothing. It should still be perfectly fine unless your master or slave cylinder is bleeding off a little resulting in poor travel.
Not saying this is the case in your circumstance but I had a gearbox rebuilt for $1200 including in/out labour (VS 5ltr 5speed) some years ago as first gear was popping out and I didn't have the time to do it myself.
I requested everything to be replaced, all bearings and syncro's as the box had a little layshaft rattle. (I've rebuilt box's before I know what sounds are coming from where)
Upon receiving the gearbox it still had the layshaft rattle; I questioned the people and they told me it was a load of crap and couldn't hear the layshaft rattle when it was as clear as daylight. He also told me they send the gearbox's off to a specialist to rebuild. So that was that.
A few months later at a party I met a bloke and we got talking. He mentioned they do the gearbox work for the mechanical shop that I had do mine and that he remembers doing a vs 5ltr 5speed gearbox box BUT it wasn't a full rebuild; it was only to fix the first gear (he said it was just a pin that dropped out) and replace syncro's. I return to the work shop and find they have gone bust...... :)
So screwed.
90% sure it's your gearbox oil guys. I got some Motul gearbox oil put in mine and I started having the very same problem. Switched to Red Line Light Weight Shock Proof and I couldn't be happier. No problems now whatsoever. It's not recommended for newer boxes though.
Talk to a mechanic that works mainly on imports and they all recommend it.
Talk to a 'gearbox/clutch specialist mechanic' and they tell you it's a not as good as everyone thinks. I had 1 good local specialist mechanic show me the internals of 2 gearboxes that he was working on. The gearbox that had Castrol oil was nice and clean, the redline gearbox looked like someone had filled it with grease, not oil.
Each to their own I guess.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
