Hi,
I am currently looking into getting GCG to high flow my current turbo (R33 GTS25T).
This high flow involves:
Turbine Wheel - replaced and upgraded with a inconel(steel) wheel , either stage 1 or 2
Compressor Wheel - replaced and upgraded with T04 wheel, either stage 1 or 2
Bearing Pack - replace with an XTR ball bearing package
Turbine Housing - machine to accept either of the larger wheels
Compressor Housing - machined to accept either of the larger hi flow wheels
Wastegate Actuator - standard or upgradeable to have higher boost pressure as standard.
There are two stages:
Stage 1 = $2250.00 Rated @ 400hp
Stage 2 = $2450.00 Rated @ 450hp, does require other mods i.e. intercooler, fuel, etc
My goal is 250rwkw. Do you think that this highflow turbo will handle this power?
Should I go for the 400hp or 450hp solution?
Has anyone else had their turbo highflowed?
Thanks in advance :spank:
https://www.sau.com.au/forums/topic/16913-gcg-high-flow-turbo/
I don't have experience with GCG, however to get the power goal you do need more mods then just intercooler or fuel..Do you consider any after market computer?
At 250rwkw, before that, you will hit the limit of your stock fuel system (injectors and pump) and AFM...there are lots of discussion post before, B-man have experience and similar to this setup.
Is it an inconel or steel turbine wheel? They are two different materials with inconel being the superior one.
Just make sure they upgrade the turbine and match it with the compressor wheel. We’ve had 2 r33’s with mismatched turbo’s and one surged so badly I thought the compressor wheel was going to disintegrate.
As for your question, go for the 450hp version. Always handy to have some spare airflow potential in your turbo :P
Thats one way of looking at it that I never really looked at.
Local turbo builders in adelaide have the same deal though.
Buying new garret I suppose would be around the same price possibly.. :) >
I guess the only bonus is that they perform well if you were going to use your old housing essentially.
I remember looking around adelaide and finding it hard to find a builder that will make 240-300rwkw from a stock housing.
Then again there is whatsisnames turbo.. Origionally making 216rwkw with 13psi moving up to 257rwkw still on 13psi.
Originally posted by INASNT
only problem with the gcg stuff is that u have to pay them $2400 for the new turbo plus u gotta give em your old one. So it really costs u $2900 coz u loose the resale value of your old turbo.
Wow - is that right !! Sort of makes you think about it hay....
That's the problem. Do you get a 2535 for $2400 and sell your old turbo for $4-500, or go a highflow for $2400 exchange..
I still don't like the idea of running high boost. It's a shame the HKS's don't start doing much until your over 13psi :)
I wish Matt (Whatsisname) knew the specs on his turbo.. 253rwkw on 13psi !!! OMG :eek: :eek:
How about this?
A GT30-45 with the following:
Turbine bypassing valving-single or dual bypass
Boreless compressor wheel technology
Mixed flow turbine stage
Electronic bypass flow control
Ball bearing technology
Variable geometry turbine (VNT) flow control
GT30V-GT45V double axle vane configuration
Advanced VNT concept technology available
VNT looks interesting
Guest INASNT
Originally posted by -Joel-
New they are over 4k...
They aint that expensive if you buy direct from japan.
U can get the new hks 2835 pro s internal gated with the T3 flange for $3100 from japan. I been trying to get ifo if it will fit in the stock location even tho its the T3 flange coz of the size of the housing on it. I just got the quote a few days ago from greenline.
Guest INASNT
Originally posted by DREMEN
Yeah but its too much mucking around going for a HKS turbo.
I am unsure if most of these turbos will fit in the stock location :D
Thats why I think the high flow idea is better..
Australian manufacturer, warranty, etc.....
its actually quite easy, pay the $$ and in about 7-10 days u will have it at your door step!
And with HKS u know its gonna work and work well!! Just the finish of their stuff is awesome
