Guest INASNT
Originally posted by turbomad
Checkout www.horsepowerinabox.com they have new Garret GT28 400+hp or GT30 500+hp turbos for $2300.
$2400 seems like a lot for a hiflow rebuild when you can get a brand newy for less.
but do these bolt on without having to redo water and oil lines?
Originally posted by INASNT
They aint that expensive if you buy direct from japan.
U can get the new hks 2835 pro s internal gated with the T3 flange for $3100 from japan. I been trying to get ifo if it will fit in the stock location even tho its the T3 flange coz of the size of the housing on it. I just got the quote a few days ago from greenline.
How do you go about ordering a HKS turbo directly from Japan?
Guest INASNT
Originally posted by -Joel-
I was speaking to some one today who owns a performance center :) and apparently he is going to be getting in the 2535's with a T3 etc.
Those r easy to get new not easy to find secondhand
RS500
I got my pfc from nengun and getting my profec b spec II (1 of the first in aus) from greenline.
And Hikari was formed by a bunch of guys from perth and is a sponsor of Performance Forums.
I'm using a GCG T3/4 turbo at the moment.
By all accounts, on an RB25 with the right management and other bolt ons you should be able to make 250rwkw. You may find that you'll be maxing out a few of the components such as the AFM and the injectors but that's just part of the game when you push the power up I guess.
Unfortunately, this turbo on an RB20 is a problem and I've got a surging problem now. But on the RB20, with bolt ons and chip it makes 200rwkw at 1.1bar. I really do think that the housings are a bit on the small side when looking at it from a performance aspect but that's only an opinion.
I'm growing more towards a HKS GT25/30 every day but upart from the cost of the turbo itself, I'm concerned about what else has to be done to fit it to an RB20 and how much it'll all cost. I can't get an honest and straight answer anywhere.
Originally posted by SLY33
Joel, would that be JMS? Terry is en route to Japan and promises to bring back HKS 2530's and 2535's plus bigger stuff! :D
Its the southern 'Performance Center' ;)
I couldn't really hear properly as another car was being dyno'd I also heard something about a bolt on TO4 but I am most probably wrong.
Guest INASNT
Originally posted by skyzerr33
instant get it right
hikari's is from adeliade and nengun is an ex pat perthite.
nengun, taka both have similar prices and deliver pretty quick
hikari was abit slow for my liking haven't used the others.
first get my nick right, INASNT not instant! :D
i was close, makes no difference.
how long did hikari take?
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
