Hi there,
I have to get a new turbo for my GTSt as the old (stock) one died a sudden death. The guys doing the job have been ringing around to see what will fit my car with minimum fuss. (bearing one - not ceramic).
I know (from reading other posts mainly) that there are quite a few different turbos that people use but everyone the performance guy's spoke to said nothing will just bolt on but you will have to do ALOT of plumbing. (and hence make the job more and more expensive.) I want to get some change out of $3000 for the job.
Is this true? Is there anything that will just bolt on (or not require hours and hours of extra plumbing work)
Thanks
Guy
https://www.sau.com.au/forums/topic/16915-turbo-for-r33-gts-t/
Hi Lachlan,
To cut a very long story short, my car dealer missdiagnosed an oil leak from the turbo area of car. Nothing to worry about I was told. Fix at next service. Said a oil pipe must have gone brittle. They do that with the heat etc...
I ordered a Microtech ECU and decided to get everything tuned, services etc when the computer came in. This however took about four months.
When the service guy took the housing of the Turbo to fix leak, he discovered that the seal was rooted and there was a HEAP of 'play' in there. (I could presssomething in and out that I shouldn't have been able to)
He even refuses to drive the car in his workshop as he is scared the turbo will break/seize (whatever they do when wrecked !)
I had the boost set on standard. I do not drive hard at all. I have never raced my car. However I now believe the previous owner did.
It used to have a HKS EVC with boost set to 12psi. I am now selling that. It has a huge intercooler now. Fuel cut off defender ??? POD, and I think a heap of other stuff. The mechanic said 'My car should be sponcered by HKS !!'
I am really annoyed at the moment as I have to pay for a new turbo just four months after I bought the car. Even though the thing was on the way out when I bought the car !
Sorry for this rant, but I am left with a sick feeling in my stomach over all this... I don't know who to blame - me for not knowing anything about these cars when I bought it or the car dealer seeing me coming !
Thanks
Guy
The problem is that most ceramic turbos are "on their way out"
Think about the car being around 7 years old, and most people don't buy a performance car to drive around slowly in.
Most if not all import performance cars have been thrashed in their lives!
Thats just part and parcel of buying an import.
Perhaps if you wanted to drive a car slowly then a holden would of been more suited to your needs :P
Hi flow, is when they take off the turbine and compressor covers and bore them out, allowing bigger (steel) wheels to be placed in there.
If you dont have alot of money to spend, you could buy a good second hand turbo for $400-$700 and put that on. If you want to high flow your old one when you have the money, and sell the 2nd hand one that you put on in the mean time to recoupe the money you spent.
Just some ideas
High flow involves:
Turbine Wheel - replaced and upgraded with a inconel(steel) wheel , either stage 1 or 2
Compressor Wheel - replaced and upgraded with T04 wheel, either stage 1 or 2
Bearing Pack - replace with an XTR ball bearing package
Turbine Housing - machine to accept either of the larger wheels
Compressor Housing - machined to accept either of the larger hi flow wheels
Wastegate Actuator - standard or upgradeable to have higher boost pressure as standard
Actually DREMEN, I never thought about it that way ! I don't drive slowely - I just don't race the car at the strip. When computer, "TURBO" etc are done though I will see what I can do the 1/4 in though...
I want to see how I go against some of the hot Starlets/GTiR's/etc that are around Toowoomba !!
Anyway , thanks again for help people...
Catcha
Freebaggin,
No it's not stuffed. Actually what happend was I had an alarm fitted, and the when I got the car back all the boost settings were gone and it was a real pain to reset everything. Real pain.
A mate offered me $500 for it (an old BMW he has done up - 12 seconds !!) and the guy at the performance centre said that I didn't need it when the Microtech was fitted so I took the cash.
Aparently I can bet a much better one for $800 if I realy wanted one. (not sure what brand though - Autospeed.com have been advertising them lately)
The guy at the performacnce centre actually chose a turbo this arvo. I will get the specs tommow. I know it is rated to 500hp and can easily be boosted to 20lb. it is $2300 + fitting (approx $400) - (I just have to sell my TV/stereo/video camera first - lol, so I can afford it.)
He said later on I can then up the injectors and do something simple to the turbo (I forget what he said) and "It will really get crackin" He mentioned 300HP at the wheels !!
gjb977 just remember the stock engine internals wont like running at anything above 16-17psi for long/hard periods, the injectors will need replacing to keep up with the flow plus you'll need an aftermarket ecu to make the most of it all without a little bit of careful thought you could end up doing more damage then good. Do searches on these forums, you'll find a lot of information on them for pretty good sources in regards to what you can and cant do on the stock internal engine.
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
    • WRXs are a pure pleb boring car these days. You need to get an STI to even get close to what a WRX used to be.
