I have a series 1 R33 Gts-t and am about to upgrade to a 32 with a GTR33 RB26DETT in it.
In the 33 I have Splitfire Coilpacks and am wondering if I can put these in the other car.
So pretty much - Series 1 Rb25DET coil packs into a 33 RB26DETT.
Will they work? Will it stuff the engine? Or will it do nothing?
https://www.sau.com.au/forums/topic/169194-coilpacks-out-of-gts-t-into-gtr/
a good reference is found in the trader section, this is taken from slidin's
as u can see, the s1 r33 gtst and the r33 gtr use the same part >_<
Splitfire Coil Packs Nissan Skyline R32 GTST, Model Number SF-DIS-001,
Splitfire Coil Packs Nissan Skyline R32 GTR, Model Number SF-DIS-001,
Splitfire Coil Packs Nissan Skyline R33 GTST Series 1, Model Number SF-DIS-001,
Splitfire Coil Packs Nissan Skyline R33 GTST Series 2, Model Number SF-DIS-005,
Splitfire Coil Packs Nissan Skyline R33 GTR, Model Number SF-DIS-001,
Splitfire Coil Packs Nissan Skyline R34 GTT, Model Number SF-DIS-008,
Splitfire Coil Packs Nissan Skyline R34 GTR, Model Number SF-DIS-005,
Splitfire Coil Packs Nissan Silvia S13 PS13 SR20DET, Model Number SF-DIS-004,
Splitfire Coil Packs Nissan Silvia S13 RPS13 SR20DET, Model Number SF-DIS-004,
Splitfire Coil Packs Nissan Silvia S13 180SX SR20DET, Model Number SF-DIS-004,
Splitfire Coil Packs Nissan Silvia S14 Series 1 SR20DET, Model Number SF-DIS-004,
Splitfire Coil Packs Nissan Silvia S14 Series 2 SR20DET, Model Number SF-DIS-004,
Splitfire Coil Packs Nissan Silvia S15 SR20DET, Model Number SF-DIS-004,
Edited by InterCooL
    • Is the 650rpm idle on the rb25det neo for stock cars only? I've never had my car before and after tuning it to idle at 650rpm when cold. Always idle's cold around 1100rpm, and then drops to about 900-950rpm. I've heard the r33 gtst's idle there.
    • Series 1 RB25DET 5 speed gearbox, push type, 1st and 2nd gear syncros worn, may need bearings. Comes with quick shift, Tomei gear knob, release fork, bearing carrier, master and slave cylinder. $850. Cusco Super Single clutch,assembly, 225mm, used, comes with a Direct Clutch solid centre 5 puck ceramic clutch plate. $290. RB26 cams used, excellent condition. $280. HDI GT2 intercooler, excellent condition, has 3 inch piping welded to inlet and outlet. $250. All items located in South Eastern Melbourne. Please PM me if interested.
    • Hi all, I’m currently running a str pipe hi low hks exhaust and downpipe. Was wondering if I change out muffler to a titanium one will it change the sound of the exhaust? Plus I have always liked the look of the titanium pipes … anyone have recommendations to one?    side note already have titanium intake pipes.
    • I looked up my other car that is a R33 GTST series 1.5. Anyone able to confirm what a Aero Form Bumper is?     (1G) 2 Door Coupe; (2GK + 11V) RB25DET; (4B) 2WD HICAS; (7F) 5 Speed Manual; (14G) Super Fine Hard Coat; (15U) Large Rear Spoiler + Aero Form Bumper + Rear Wiper (Aero Selection)
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
