Qld: Various Turbo/skyline Parts
A couple of months of gentle driving will be fine. There is a risk that you will kill it. A heavy workout will probably kill 3rd gear. Continued use will wreck the input shaft bearing.
That's because R34 RB25DET is a pull clutch gearbox. I have that clutch, behind 25Neo, in front of R33 gearbox. I have brand new R34 turbo gearbox, in a box (cardboard) in the shed right now, and it will be getting used with the same engine and clutch, because I also have, in a much smaller box next to it, the front plate to convert the new box to push clutch.
Are you planning to ever come on boost with the RB25DET? The torque of the motor alone will break the little box. It's not a matter of if, it's when.
So it should work in my case? I does not say R34 but it say push(i have push gearbox/clutch right now) No i wont...and i do not drift/race or do anything crazy with car so even a small box should be ok for a couple of months
Ha ha, yeah, I've had one following me around in my parts boxes since about 2007 I believe. Just a little iddy bit hole drilled in the one I have to let it vent out once pressure was removed from the engine side. Still no idea what I'd put it on, ha ha.
