dont bother. it works but its better to get it re-trimmed. you can actually tell its been srayed coz you'll never get the entire plush of the liner. the only other thing you can do is get a die and wash the liner in a die to change its colour.
https://www.sau.com.au/forums/topic/169220-carpet-spray/#findComment-3128731
Hello guys, I am new here. I will introduce myself in the correct way, once I have some pictures of my new motor to show you :D
Cruzin, I want to take my roof liner out too (and dye it) but do not know how to do it. I would appreciate it if you could let me how you did it. Many thanks.
B
https://www.sau.com.au/forums/topic/169220-carpet-spray/#findComment-3133973
if u wanna re-trim it, easy as pie, using a contact adhesive in a spray, spray the liner then lay the new material on it and using some sand or dirt, put it on top of some plastic on the fabric to apply even pressure over night. next morn, remove sand, curl ends around and using a short profile staple, fasten it down or use the glue again with tape as this part isnt seen. and done. will look heaps better.
https://www.sau.com.au/forums/topic/169220-carpet-spray/#findComment-3141280
On my r33 sr1 i just removed all the plastic around the liner(cliped on) then removed the covers of the sun viser's,miror and the cabin light to get to the screw's. Unpluged the wire to light and 4 clips holding the liner up then she was removed.
https://www.sau.com.au/forums/topic/169220-carpet-spray/#findComment-3141406
