Hey guys,
wanted to see if anyone has one fitted.
Pics anyone?
yes it would look disgusting and out of place, although i want to know if you can have one made that is removable that doesn't have to be cut out of your rear bar.. one that comes out and curves up that can be hidden under the car when not in use.
basically i have a boat and not enough money for another car to tow it with!.
Any ideas good places to ask in sydney..
cheers
https://www.sau.com.au/forums/topic/169238-r33-tow-bar/
Anyone know who i should see in regards to getting one made up? im in sydney...
I read the other thread.. seems like a job for someone else... i dont want any holes in my bumper i want it to be removable and clear the contours of my rear bar....
https://www.sau.com.au/forums/topic/169238-r33-tow-bar/#findComment-3134471
How much weight would your boat+trailer weigh?
Is this a little dingy?
yep a tinny.... weighs nothin...
boat weighs 80
50 hp motor weighs 74
trailer around 100
so max 250 ish...
yes its a big power to weight!!
https://www.sau.com.au/forums/topic/169238-r33-tow-bar/#findComment-3146933
I currently have two cars, have a VN Calais with a tow bar which comes in handy for pulling a trailer, or chucking the bikes in the back seat, or whacking roof racks on and strapping a kayak on. I want to sell my VN, but dont think id consider putting a tow bar on the 33 to carry the bikes - just wouldnt look right! A stagea wld be handy though!
You should be able to go to any tow-bar place you trust, and they should be able to knock up a custom one fairly cheap - theres not much too em. They get the car up on the hoist, and look for places to weld to your chassis.
Edited by Trav33
https://www.sau.com.au/forums/topic/169238-r33-tow-bar/#findComment-3147002
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
    • Turbotapin   so I am about to be mounting mine up been waiting for the body to get finish at paint. I had a question. I was told our Speedo sensor it originally in the transmission but the cd009 is in the diff on the z. How did you get around this?
    • I definitely do recommend having a fab/grinding/dirty shed or area to keep all that grinding dust out of your main shed.  But you're right, it doesn't matter how much room you have you still end up filling it! I might even do a short video which will make it easier to fully take in the horrors of what I've created...
