3 Piece Wheels
hi im after some advice on what to use as a sealer inbetween the wheel centre and rim and a cleaner that may remove the soft silicone that i have scraped off thanks loren
Whats to explain?
3 piece rims have an inner, an outer and a center section.
The inner and outer sections have a flange and the bolts go through the 2 flanges and through the edge of the center section to hold all 3 bits together.
A leak through the bolt hole means that the sealant thats normally covering the joint has come away (probably due to age).
Personally Loren, i'd take the whole thing to a decent wheel repair place and tell them to re seal it as you will have to strip the tyre and possibly disassemble the rim to do it properly. If you're in Sydney try Morton and May at Warwick Farm.
Whats to explain?
Ive never seen a 3 peice wheel up close b4.
i had to do this with a set of rims i used windscreen sealant, but it is a pain in the ass job to do you have to strip the trye, dismantle the rim and clean all of the exsisting sealant off, the rim needs to be perfectly clean otherwise it will leak again, the truck i found was not to use huge amounts of sealent, after two attempts i got it to seal nicely
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
