GCG HIFLOW TURBO FORSALE TO SUIT RB25.
VERY LOW KMS SINCE HIFLOW
ALSO INCLUDES 3.5IN DUMP TO SUIT
ASKING $1400 WHICH WORKS OUT AT AROUND $1100-1200 IF YOU SELL YOUR EXISTING TURBO
PM IF INTERESTED
Edited by yld_33r
https://www.sau.com.au/forums/topic/169281-gcg-hiflow-for-rb25/
you got some pics of it? how many k's since being hi flowed? is the dump just a dump or 1 pipe (dump front in 1).
location?
sorry no pics yet. done about 6000kms since hiflow so is as new and its just a dump, not a dump/front pipe.
I think you'll find that neither of them post up the exact specs but if you're just after a rating, the GCG is suppossed to be 450hp (i think)
Also, GCG is ball bearing, slide is Journal bearing
Costs more than that just to Hiflow, this turbo is a bargain. Best part is it bolts up without any mods, same manifold, same oil, same water etc. Better than an aftermarket unit. I made 250rwkw and it was a blast to drive, absolutely hammered.
Good luck with the sale.
any shaft play or damage in any way??
i got 2 standard turbos i could sell, both in ex con dition and zero shaft play if any its minimal!! be interesed in them and how much cash on top!!
Edited by FAT_3L
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
