ive been playing on a US server. I think West.
I tend to agree with higher level 1v1 games, I doubt they have to worry about shit tactics like cannon rushes.
This guy i played the other night, ran a drone down to my base and built a gateway, forge at my entrance, blocked me in with a couple cannons behind then came over the top with voids. I had no answer to it. Really pissed me off.
Been trying to expand faster (by 2min) doesnt work all the time, but it makes a massive difference with speed.
  • Replies 42
also got a keyboard that has a in built macro/key binding software for the extra keys.
I wrote some macros to select hatcheries, lava and then build whatever unit i want. That has also made me that little bit faster and easier to manage troops.
lol ye you will get idiots who do that type of thing in lower leagues/classes unfortunately.
You need to learn to use overlords to scout in that instance. Get early Lair and upgrade overlord speed = easy scouting.
Plus if he made cannons behind a gate/forge, you just make queens or roaches to push past it and then run in an dominate him.
Or use my fav weapon... Nydus Tunnels - to get your troops into his base easily.
Thats the thing with RTS - there is always a counter, you just have to know what it is and the only way is via experience and in-game scouting.
The best counter to voids early is just to make queens cause they can heal each other easily and do good dmg/range. Not too many towers as they cost minerals/drones so queens offer much better value. Hence I have usually 2 queens at each hatch to heal and defend easily as you can also heal towers with queens ;)
Once economy up and running i also make a 2nd hatch @ my main base and then have 3 queens so you can have 10-20 larve ready at any given time if you are waiting for tech or need to change units fast.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
