hey guys how are yas?
just gotta quick question that i need your help with, ok i am after a pod enclosure for my 33 gtst for my air pod.
i have spent some time doing a search and in one of the discussions the guy was talking about a full enclosure and a shield with no lid that partially covers the side of the pod and relies on the bonnet to be the top piece for the lid. he said that he did a temperature test and that there was no difference in having a full enclosure or a partial one,
could this be true?? could this really do the same job as a full box??
and also guys with having an enclosure do i diffenantly need a air intake that runs down to my front bar? or is it all right to just leave the open hole there left from the old piping as i have a front mount now? wil i definantly need the pipe running to my front bar or will there be enough air getting into there with out one??
thanks for the help...
https://www.sau.com.au/forums/topic/169309-pod-enclosure/
oh really so you think that for street use there is no need to enclose the pod hey??
so you didnt notice any differance once you got a pod shield on hey??
not worth it you reckon??
does anyone else have this opinion??
https://www.sau.com.au/forums/topic/169309-pod-enclosure/#findComment-3129601
so you think that it is very worthwhile, anyone else got any opinions on this??
yeh that is a great diy section hey. looks good to.
so does anyone have any ideas on if a closed box actually is better then an open lid one?
https://www.sau.com.au/forums/topic/169309-pod-enclosure/#findComment-3129846
That shield is about $5 worth of heat shielding foam with some rubber edging on it.
But they have the stock cold air feed feeding air to the pod which is a good thing.
I'd stick with a fully box design. The idea is to keep the hot air away from the pod and make sure the pod only sucks in cold air from outside the engine bay.
The plans I posted up (they are my plans :) )cost me about $20 to make and it made a noticable difference with reducing heatsoak.
J
https://www.sau.com.au/forums/topic/169309-pod-enclosure/#findComment-3129979
well i am stil gathering whether to make a full box design or just to do the side section of it and have the bonnet closed down on it as a lid,\
at the moment i am making my cold air intake pipe should be one the car tomorrow.
then i will go for the enclosure for it,
as i said earlier one guy on here did a test and the box design and the side section both had the same temperature results,
i didnt think this would happen as i thawt the box would be much better.
https://www.sau.com.au/forums/topic/169309-pod-enclosure/#findComment-3133755
    • Took it to all Japan day. Thrashed it all day and it will still drive home. Very very happy man right now
    • Hey Nismo, any chance in the world you still have these seats?
    • I'd say closer to OG GTX3582R, just smaller trim - so 59mm inducer/82mm exducer as opposed to 62/82 for the first gen GTX3582R. Yeah EFRs were boss, the EFR8474 is still an absolute beast and it perplexes me that people still go to things like Turbosmart/Garrett etc when the results people are getting with those are pretty unremarkable compared to what you could get with a turbo available well before those options came out.  DriftSquid (I think) "upgraded" from an EFR9174 to a Turbosmart turbo and promised a comparison video - and kinda shuffled awkwardly and did a bit of diversion from the fact that they didn't get any improvement going to the currently massively hyped brand of turbo from a turbo that was a bit of a frankenstein that had been well superceded in it's own range before the Turbosmart unit he put on there even came out. I suspect the EFR would outperform most Xonas for what a lot of less-insane RB owners would go for, in the 400-600kw range but the Xonas are looking hard to beat up to maybe in the mid 700kw range at this stage- basically where EFRs don't really reach, and before the Precision turbos take over.  What the Xonas do well in the "EFR range" is be easier to package etc, and work very well if a divided housing doesn't suit your application.
    • Are you sure the gasket is blown? What are the issues? Thermocure is the only flush I've seen do anything with rust, very impressed with that, Prestone, rust will be by the pool having a cigarette.
    • And since the flush you have a blown head gasket? Have you lifted the head off yet?
