I searched around without success.
I've reached about 95% on my AFMs and I'm looking to upgrade. I have a PFC about to go in.
Z32 appears to be the standard upgrade, but that's larger then I need. I was wondering if RB25DET AFMs would be a good upgrade. I gather two 25DET AFMs will flow more then the R32 GTR items????
Anyone done this change? Or any other suggestions.
https://www.sau.com.au/forums/topic/169320-25det-afms-in-gtr/
I'd like to know the answer as well..
Just get twin Nismo AFM's.
The are a Z32 sensor, in a stock AFM housing.
Therefore they bolt up to the factory piping. This is a key factor as it saves $$$ having to redo all the cooler piping and a lot of dicking around.
The Nismo AFM's are the next step up from the stock RB26 AFM's
Re-doing the afm piping isn't an issue as I was looking at reolacing the lot with stainless, just interested in if the rb20/25 afm was a workable upgrade or not.
Considering that I will only be paying for the materials, not the fabricating, the rb20/25's might work out cheaper than buying a pair of nismo afm's.
james.
rb20 and rb25 afm are same size and same calibration.
Rule of thumb for Air Flow meters RWKW & Engine BHP
added nismo afm onto paulr33's table
------ ---- OD ---- RWKW ---- RWKW ---- BHP ------ BHP
No of AFM's ---- ------- 1 -------- 2 -------- 1 -------- 2
RB26 ------ 65 ------ 149 ------ 299 ------ 271 ------ 474
RB20/25 --- 80 ------ 226 ------ 453 ------ 376 ------ 683
Z32 ------- 80 ------ 255 ------ 511 ------ 415 ------ 763
Nismo----65------------------570
Q45 ------- 90 ------ 302 ------ 605 ------ 479 ------ 890
Edited by andz
Yes,
I have put 2 RB25afm's on my gtr...bought for $200 dollars...second hand off a member of this forum...got them fitted...modified old intake.
Had to buy 2 adaptors from Just Jap Sydney $80.....total...
So was in for cams and retune anyway...so fitting was $200(That is cutting the Tomie pipes that were there...installation of some adaptors as mentioned and
some silicone hose and clamps....it all looks good...total cost..
$480.....
If I knew this before...would have bought the Nismo items.......direct bolt on...lol...I did not need new plugs.....
Z32's require...plug adaptors.
If I find my post I will give you a link.
Nismo/Z32 are identical. So not sure what your getting at there.
And that above table is wrong.
I made 270rwkw on PULP with a Z32 and it was nowhere near maxing out. Same as a lot of other peoples.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
