  • Replies 52
prepare to be recorected... :spank: .mine runs for 5 minutes before it turns its self of
seires 2, ... mine runs for ages, one morning turned it on via remote ... hard to do some things that took longer then expected 10mins plus.
only turns off when any door is opened, which is very silly but has it reason also.
stopped using my remote as the alarm started to play up wouldnt disarm itself when i tried to unlock it. very embarrasing moment at a crowded carpark :down:
i have been dreaming of this day since before i had my stagea . but my car doesnt have the switch . cant find it and no screw holes in the kick panel . can someone pretty please tell me what color code of the wires or where it goes into the loom . i have a small white 2 prong connector near this location . has a purple / white stripe and a red n yellow one . or pictures please
Remote starters were an optional extra on autos only so no soup for you!
what the hell is that box?? i got one with my M35 as well. doesnt appear to work!
Was an immobiliser/alarm fitted since arrival in Oz? If so your starter probably won't work. If not, try changing the batteries then push the 'check' button whilst near the car. The headlights should flash on then off for 1/2 a second.
Good luck!
Good luck!
nah no alarm or anything was added. but ill try changing the battery. thanks, i really should have thought of that myself lol
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
