Help has any one fitted a HKS super AFC and can let me know a starting point for settings
It has a 3†straight though exhaust turbo elbow & multi branch manifold + Apex filter
Would like to try ball park figures until I can get booked in for dyno have to wait a few weeks
Until new boost controller arrives??
Thanks for any info John
Stagea RS4 1996 auto RB25DET
Edited by wildrat
https://www.sau.com.au/forums/topic/169346-hks-super-afc-settings-help/
Don't know about a HKS safc but could help you out with an Apexi safc :) lol
I'm assuming you got all the setting right as far as sensor type, cylinders, tps direction and your car is starting and running fine etc etc? And your just after some settings for the mapping? If this is right just leave them all dead flat until you can get it on a Dyno. Every car is different (even though they may have identical mods etc.) but its not worth the risk trying to ball park it. I could give you my hi and lo throttle settings and they would probably be fine but if you have a crook fuel pump for one example then your in big trouble and your not going to know till its too late.
Just wait the few week man.
But if you need help with the initial settings for your cars sensors and type etc. Then let us know what you need and we'll be able to help out.
Bought the unit second hand and was fitted to an Evo before have got it running OK (correct settings Etc.)
Would of liked to see some conservative settings (better than standard) until can get to dyno
I have been given a 4 week wait for the dyno as am out in the sticks here
Was hoping someone down there had the settings close enough until I can get it in that was all
If you do have the throttle settings that would be a start
Thanks john
I could give you my high and low throttle settings but if the car leans out and you smash a ring land etc, from detonation (pinging) I don't want to be held responsible in anyway and you do so at your own risk. I'm also using a apexi SITC for ignition timing control so my timing has been advanced untill 2500rpm then retarded high up from around 5000. Personally I wouldn't risk it, whats a 4 week wait for a dyno compared to a possible dead engine. BUT if your still dead keen PM me and I will give them to you
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
