*** SOLD ***
Selling my daily as I've bought another car
1990 Nissan Pulsar Q (series2)
1.8L fuel injected engine
5 speed manual with LSD
273,000km
Kenwood CD player with 4 speakers
Sports steering wheel
Rego till mid-August
Km are high, but the car has been very reliable since I got it about 12 months ago. Did QLD to melb and back over xmas without any dramas and I've driven it every day to work. Body is very straight, no major rust, no oil leaks. Parts for this are very cheap if you do have to replace anything, and a CA18DE or CA18DET is a fairly easy swap if you wanted to have fun with it.
Aircon is fitted, but not working (gas? not sure).
Just changed all the brake pads, and have serviced it a few times since I bought it. just had $800 worth of work for safety certificate including 4 new tyres, and CV joint replaced
Price
$1600 with safety cert and 3 months rego remaining
I'm on the goldcoast. PM or email [email protected]
cheers
    • Not far. If all you want to do is know that they will reciprocate and move oil around a tiny bit, then a metre or so is all you need. Half metre fore and aft is enough.
    • That's the spirit!
    • It's fine. Basically if it has seized (eg due to moisture/rust in the bores) it will either break free on the starter or it won't turn....then you'll know it is freed up If it turns and doesn't start (reasonably likely) you will need to troubleshoot but most likely issue is a seized injector from moisture; same if it starts but missfires. Anything else could have happened (eg mice nibbling electricals) but the only way to find out is to close your eyes and hit the key I'd also change the fuel filter again after a few minutes of running as it may catch a heap of crap on first start
    • Excellent...maybe even instead of RB rebuild start with 6L LS and add boost for good measure!
    • This sounds do-able except space is a little tight were it's currently sitting. How many metres you reckon it would need to go?
