  • Replies 48
Mate, I'm after a drivers side-door mini coin pocket holder thing.
See picture - firstly, where are you located? I am happy to give you, say, $25.00 for this.
Pic courtesy of nizmokid - hope you don't mind me borrowing the pic.
Thanks,
SEE THE PIC WITH RED ARROW.
  • 1 month later...
hey dude do u have the relay for the dash light dimmer its located in the picture where its circled in red if you do can you email me at [email protected]
Edited by ERR33T
Two front shocks?
What condition are they in?
Is there a car that's had rear end damage, as i see on the first post, your car has front damage, but you say you're wrecking two cars.
