ok im chasing both gear and handbrake boots long as they in good nick no rips or fraying
also need the piece in the horn button assembly that contacts the terminals for the horn or even the whole centre piece will do..
also the snorkel for the factory airbox
and also maybe the driver door window switch mines a bit funny but still works tho
let me know cheers
Edited by wizard2k
  • Replies 48
  • 4 months later...
  • 4 weeks later...
hey mate, im after the rubber that runs along the door frame. What condition are they in, i need both passenger and driver side. Also need driver side headlight if urs isnt misty - please provide pic if you can so i can see the condition.
Edited by Skyline_95GTS
  • 1 month later...
  • 3 months later...
